where do I get GOOD electrical tape, sort of off topic, but using it on a 914 |
brant |
Sep 19 2016, 10:58 AM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I'm sick of crappy electrical tape
I keep throwing rolls away that probably came in a multi-pack so they are either not sticky, or gummy... crappy crappy tape that lets go in no time what are you guys using for quality electrical tape? I'd like to buy some fresh stuff and stay away from the cheap crappy big box tape I seem to already have thanks for tips brant |
'73-914kid |
Sep 19 2016, 11:10 AM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
I avoid electrical tape like the plague. It's either heat shrink or cloth TESA tape only in my toolbox. I HATE the leftover adhesive that electrical tape always leaves behind.
Mueller |
Sep 19 2016, 11:11 AM
I'm sick of crappy electrical tape I keep throwing rolls away that probably came in a multi-pack so they are either not sticky, or gummy... crappy crappy tape that lets go in no time what are you guys using for quality electrical tape? I'd like to buy some fresh stuff and stay away from the cheap crappy big box tape I seem to already have thanks for tips brant Scotch brand, Super33+ |
Mueller |
Sep 19 2016, 11:13 AM
I avoid electrical tape like the plague. It's either heat shrink or cloth TESA tape only in my toolbox. I HATE the leftover adhesive that electrical tape always leaves behind. I have a few rolls of that stuff as well, even wrapped a few hand tools and our Pinata beating club with it! |
malcolm2 |
Sep 19 2016, 11:20 AM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
it is not always pretty, but the liquid tape seems to do the trick. i'll have to read the label about being water tight tho.
You have to be patient and wait a while after application or you rub it off and it gets on other stuff. It comes in several colors too. |
db9146 |
Sep 19 2016, 11:59 AM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Depending upon the use, the self-sealing "tape" (its more like rubber in how it feels and stretches) is a good choice. It adheres only to itself and fuses into a liquid-tight seal (within reason). Its good for sealing joints that are already together where you can't get heat-shrink tubing in place.
wndsnd |
Sep 19 2016, 02:26 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I'm sick of crappy electrical tape I keep throwing rolls away that probably came in a multi-pack so they are either not sticky, or gummy... crappy crappy tape that lets go in no time what are you guys using for quality electrical tape? I'd like to buy some fresh stuff and stay away from the cheap crappy big box tape I seem to already have thanks for tips brant Scotch brand, Super33+ Agree, It is the best, or Super 88 if you want a little thicker. Get at local Electrical Supply Distributor BTW it is 3M's Brand |
michael7810 |
Sep 19 2016, 02:30 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Ace hardware has some black cloth tape that works well and kinda stick to itself and forms a good seal. Not sure if it's the "TESA" tape mentioned above.
SixerJ |
Sep 19 2016, 02:38 PM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
I avoid electrical tape like the plague. It's either heat shrink or cloth TESA tape only in my toolbox. I HATE the leftover adhesive that electrical tape always leaves behind. Second for Tesa tape for loom work, fab stuff and very factory. Stay away from the Chinese knock offs that are on fleebay |
rgalla9146 |
Sep 19 2016, 03:24 PM
Advanced Member Group: Members Posts: 4,555 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Isn't the cloth stuff called friction tape ? Electrical supply house would be my choice. 3M or Scotch |
Andyrew |
Sep 19 2016, 03:25 PM
TESA tape/ the cloth tape is all I use anymore. I buy it on amazon for 8 bucks for a big roll. Used 2 rolls doing my wiring projects on the Audi swap so I can tell you it goes a long ways.
Garland |
Sep 19 2016, 03:27 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Coroplast cloth tape 3/4 wide. You cannot tear this tape it must be cut. Waterproof sticks very well.
Jon H. |
Sep 19 2016, 03:47 PM
Member Group: Members Posts: 237 Joined: 1-July 11 From: Ottawa, Canada Member No.: 13,264 Region Association: Canada |
Yep, super 88!!
Regards' Jon h. |
Mike Bellis |
Sep 19 2016, 07:59 PM
If you want something non sticky...
Cold Fusion or Self Fusion Tape. This stuff is awesome and fuses to itself without glue. http://www.mcmelectronics.com/product/SPC-...11100-/21-11100 |
Lo-Fi Version | Time is now: 19th May 2024 - 09:56 AM |
