daughters' @$%@$@#$@# 1.8, relays/harness?/computer |
porbmw |
Sep 20 2016, 12:00 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
Damn
Damn Damn Damn 1.8 Now that I have vented. Planned to have my daughter get more miles under her seat this summer....it had been sitting while she was away at college for 2 years. Anyway, have an intermittent problem, looks like I need parts....to troubleshoot and fix. VERY rarely, but often enough that she cannot go across a bridge, or on the freeway...it cuts out. Fuel pressure exists, so likely not fuel pump. Injectors seem to work.... Plan A Need the 2 relays that are below the battery...I believe they are described somewhat as follows... a)dual relay, and b)fuel resistor pack. I KNOW that is not likely the proper description, but hopefully it is close enough for "you in the know". Plan B If those 2 relays don't work, perhaps get wiring harnessed reconditioned.....Jeff???? Plan C Computer Plan D Carbs Plan E Selll the car..this will really frost me, since it is a nice car, and would like to see more young people AND girls driving/enjoying these. Anyway.... For starters...anyone have the relays...as with the other parts, I gather they are unique to the 1.8 Thanks Paul |
mojorisen914 |
Sep 20 2016, 04:06 PM
Visit your local strip club Group: Members Posts: 695 Joined: 9-July 06 From: Denver Colorado Member No.: 6,403 Region Association: Rocky Mountains |
Let me look tonight. Do you have part #'s for them?
timothy_nd28 |
Sep 20 2016, 08:08 PM
I understand the frustrations. Why not diagnose this before randomly buying parts? I'd be happy to assist.
bdstone914 |
Sep 20 2016, 08:32 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
If you do need any of those relay I should have them. |
porbmw |
Sep 20 2016, 10:10 PM
I understand the frustrations. Why not diagnose this before randomly buying parts? I'd be happy to assist. Thanks for the offer. I will confess that I would be of little use in diagnosing...or helping. My buddy is a Mercedes tech, but has worked on Porsche and vwdubs as his hobby "forever". I think he has narrowed it down about as far as he can, without starting to plug in bits to rule out the defective parts. I understand he believes the most likely culprit is either the relays...or the wiring harness...with less likelihood on the computer... So I am hoping the relay swap will do the trick...and if not, I would put odds on the harness...don't know how hard it would be to go thru the entire harness to rule out or better define? Again, thanks for the offer. Paul |
porbmw |
Sep 20 2016, 10:15 PM
Let me look tonight. Do you have part #'s for them? The car is at my buddy's shop (relegated now to the outside, in the dark) He tells me that the "dual relay" (which I gather is very likely unique to the 1.8) has 2 part numbers as follows: Audi 02290659 and (likely either VW or Bosch) 0332514102 The "resistor pack" as he calls it, has numbers that are rather indecipherable (but he believes is not likely unique to the 1.8...it is apparently about 2 and 1/2 inches by about 3/4 Thanks |
porbmw |
Sep 20 2016, 10:16 PM
Hi Bruce Thanks for the post. Please see that above two posts. Appreciate the help from all sources. Paul |
timothy_nd28 |
Sep 20 2016, 11:04 PM
So your friend is a part changer? Have him post a thread in the garage, I will walk him through and diagnose to a specific component. The guessing game he's playing could be expensive.
porbmw |
Sep 21 2016, 12:10 PM
porbmw |
Sep 21 2016, 12:24 PM
Let me look tonight. Do you have part #'s for them? Hi Will send PM Thanks for offering to look for the parts. Don't want to inconvenience anyone...ie...more than one person hunting around. Please let me know if you are able to locate, or have time...and if not, I will ask Bruce if he has time etc. Again, thanks Paul |
Lo-Fi Version | Time is now: 20th May 2024 - 08:53 AM |
