| JeffBowlsby |
Jun 23 2003, 02:08 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,264 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
The following wiring harnesses and related services are available for the 914 Porsche owner:
* Rebuilt D-Jet Fuel Injection Harnesses (1.7 and 2.0L cars) * Rebuilt Ignition Harnesses (All 4 cylinder 914 cars) * NEW Alternator Harnesses (All 4 cylinder 914 cars) * Repairs to any 914 Porsche wiring harness including the 1.8L L-Jet FI harnesses - Free estimates! * Throttle position sensor calibration plugs * Oil Temp sender wires for the 1973-76 cars All replacement harnesses use correct color coded wiring and new components, and come with a limited warranty. Most items are stocked for immediate shipment. Further the details are on my website: http://bowlsby.net/914/WiringHarnesses Attached image(s)
| Dave Cawdrey |
Jun 23 2003, 02:22 PM
Dumbo going poop, Daddy :) ![]() ![]() ![]() Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 |
I have the new alt. harness, and I must say the quality is outstanding. If I ever go back to FI, I will buy the new harness to rule out any wire problems (you know, cuz FI has many "issues").
Satisfied customer... (IMG:style_emoticons/default/smilie_pokal.gif) |
| robby750 |
Jul 5 2003, 10:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 646 Joined: 6-April 03 From: Lexington, Ky Member No.: 521 Region Association: South East States |
I just installed my new injection harness and could not be more pleased. The quality of material, workmanship, and instructions is excellent. This item cured an intermittant misfire problem that I had and the engine has never run smoother. Highly recommended! Thanks, Bowlsby. (IMG:style_emoticons/default/smilie_pokal.gif)
| Queenie |
Oct 9 2003, 04:33 PM
Society Is A Hole ![]() ![]() Group: Members Posts: 383 Joined: 14-July 03 From: SLO-CA Member No.: 908 |
I received my harnesses yesterday and they're absolutely wonderful. The care taken with them really shows; this is work of the highest caliber. In addition to the excellent quality of the goods, Jeff is a wonderful person to deal with. He was extremely kind in working quickly for me as I had a limited amount of time available in which to complete my repair job, and his communications with me were prompt and pleasant.
If you need wiring harnesses, this is the place to get them. Accept no substitutes! |
| redshift |
Jan 9 2004, 01:45 AM
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Just looking at your harnesses Bowlsby... what an excellent job..
M |
| eldiosyeldiablo |
Feb 5 2004, 09:59 PM
Member ![]() ![]() Group: Members Posts: 129 Joined: 19-August 03 From: Roswell, GA Member No.: 1,047 |
I just got mine in the mail and removed the old FI and Engine harness tonight. Man I knew my old ones were crap but wow they are shot.
Jeff's wires look very solid and well done. The test will be when I plug them in. (IMG:style_emoticons/default/beerchug.gif) |
| seanery |
Jun 22 2004, 08:37 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Jeff,
my car's engine harness is stiff. Car has carbs now, if I sent you the old one, could you duplicate it? If so how much $ and how much time? thanks, sean |
| Gint |
Jun 22 2004, 09:47 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,108 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
As long as we're on the subject I have to ask again. (IMG:style_emoticons/default/biggrin.gif)
Jeff, can you go through my /6 harness (complete) and check/repair/replace as necessary? |
| JeffBowlsby |
Jun 29 2004, 01:35 PM
Sean and Mike G, PM sent and posted here too:
Sean: Sure...if by 'engine harness you refer to what I call the ignition harness...the stock FI and carb set-up are very similar. I can just delete the AAR wire and voila... Or if you need a very customized harness I would need to see your harness... Mike: Sure...If there are any critical connector housings that are missing we wil need to find replacements...but the wiring and wire terminals and casing we can tackle... |
| Gint |
Jun 30 2004, 08:09 AM
Thanks Jeff. I'll dig out my harness this weekend and get it cleaned up and have a look at it.
| Eric_Ciampa |
Aug 7 2004, 01:05 PM
CHAMP914 ![]() ![]() Group: Members Posts: 154 Joined: 3-April 03 From: Placerville, CA Member No.: 511 Region Association: Northern California
Do you do L-jet harnesses and what kind of prices are we talking about?
| JeffBowlsby |
Sep 2 2004, 02:03 PM
Hi Eric, while I dont rebuild the L-Jet FI harnesses, I do repair them. The pricing all depends on what needs to be done. If you will send it to me I offer a no-cost repair estimate.
I do rebuild the alternator and engine harnesses for the L-Jet cars though... See my website for details. |
| Eric_Shea |
Sep 16 2004, 07:28 AM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Jeff,
While looking over Gint's harness, might you be able to duplicate parts of it (engine harness) using a 74 FI harness as a donor? I'm putting a carb'd six in mine. Karl mentioned some similarities while lunching at the MWC but I don't recall... |
| JeffBowlsby |
Sep 20 2004, 09:35 PM
Not possible Eric...
The Sixer engine bay harness integrates all engine bay functions...ignition, alternator, battery cable to starter, oil pressure/temp and other things into one harness with about half a dozen special connectors and parts that are NLA anywhere. Believe me I have tried to find donor harnesses and there are none to be had inexpensively. Even the early 911 Sixer harnesses use different parts and a donor is very $$$. |
| rickyhgarcia |
Dec 18 2004, 09:34 PM
UPS truck is here... ![]() ![]() Group: Members Posts: 293 Joined: 13-June 04 From: Miami, Florida Member No.: 2,198 |
I will be upgrading my engine within the next few months. I´ll have Jake Raby built my engine with 103mm Nickies. The engine configuration will include 4IDF Webbers carbs. I would like to use this opportunity to replace my 30 year old harnesses. Which harnesses do I need to change? My car is a 1974 with the 2 liter engine.
BTW, I bought the early 914/914-6 left gauge which incorporates the oil temp readout. Would this gauge effect the harness |
| JeffBowlsby |
Feb 24 2005, 05:02 PM
Anyone who attends the WCC 2005 will have an opportunity to not only see my wiring harnesses, but will also have the opportunity to win Gift Certificates good towards new harnesses for your car.
See you in Camarillo! |
| echocanyons |
Mar 22 2005, 12:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,117 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California
Outstanding work Jeff.
I just recieved my new harness and it looks to be superbly made. |
| Gint |
Apr 1 2005, 09:12 AM
I drug my feet on this (too!). Harness will be coming soon Jeff. I'll email ya.
| bcheney |
Nov 7 2005, 09:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
Just recieved my engine harness. Will be installing soon. The quality of his work is excellent. If your harness is suspect, Jeff is the right guy to deal with!
| 914werke |
Nov 8 2005, 11:31 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,679 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Jeff while I am happy with my FI harness and egarly anticipate applying to my restored LE, the CW part of me cant help but wish that the shielding/cover were the OE grey rather than the black. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Is it possible? |
Lo-Fi Version | Time is now: 8th June 2026 - 11:50 PM |
