WTB: Ignition Lock tumbler Switch, Key preferred but will buy without |
R_u_dd |
Sep 22 2016, 06:57 PM
Member Group: Members Posts: 154 Joined: 3-March 14 From: Grants Pass, Oregon Member No.: 17,072 Region Association: Pacific Northwest |
I am looking for a 1971 ignition lock. It looks like so:
Picture here. Part number 914.347.019.00 I don't necessarily need the switch but the lock and tumbler. In 1971 they were a bit shorter than the 72 and later. They no longer make the lock for an early car. It appears that they are made for the later cars only. If anyone knows whether you can disassemble the lock on a later car and put the tumbler into the slot. I have the cylinder but not the tumbler. Thanks, Chris |
Luke M |
Sep 23 2016, 11:07 AM
Senior Member Group: Members Posts: 1,371 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I may have one from my 71 that I parted out years ago.
Give me sometime to go dig through some boxes and I'll get back to you. Found it but it's missing the rear tab piece. It's also missing the key. Pm me if you're interested to work out the details. Attached image(s) |
R_u_dd |
Sep 23 2016, 12:39 PM
I may have one from my 71 that I parted out years ago. Give me sometime to go dig through some boxes and I'll get back to you. Thanks. I was just at a wreaking yard and discovered two 914's which I will post in the. VIN database. Between the two cars he only has one ignition and will not part with it. I was happy to learn that he will be restoring the cars rather than parting them out. Let me know if you find the ignition switch. It's a.bugger to get it out but there is a good thread on how to do it in the info section of 914 world. |
R_u_dd |
Sep 23 2016, 07:25 PM
I may have one from my 71 that I parted out years ago. Give me sometime to go dig through some boxes and I'll get back to you. Found it but it's missing the rear tab piece. It's also missing the key. Pm me if you're interested to work out the details. I may just give that a try. If a key goes through the tumbler and is what actually moves the switch, it might work. Not sure. I might also use it to plug the hole and put a button elsewhere??? PM on the way. If anyone else can find one, I'm still in the market. |
Lo-Fi Version | Time is now: 10th May 2024 - 12:56 PM |
