Crack, or normal casting? |
74ravenna |
Sep 24 2016, 10:04 AM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
earossi |
Sep 24 2016, 07:15 PM
Member Group: Members Posts: 210 Joined: 8-December 11 From: Chicago, Il Member No.: 13,878 Region Association: Upper MidWest |
Appears to be a surface crack in the spigot on a cylinder. The problem with surface cracks is that with temperature cycling, they will usually propagate. The way to deal with any crack is to grind out the crater until the crack vanishes. Surface cracks in castings usually grind out with very little effort. But, if the crack is found to have propagated through most of the thickness of the casting, you may suffer failure of the spigot.
stugray |
Sep 25 2016, 01:28 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Appears to be a surface crack in the spigot on a cylinder. The problem with surface cracks is that with temperature cycling, they will usually propagate. The way to deal with any crack is to grind out the crater until the crack vanishes. Surface cracks in castings usually grind out with very little effort. But, if the crack is found to have propagated through most of the thickness of the casting, you may suffer failure of the spigot. If that was a crack, my engine would have fallen apart already. Mine is covered with them. |
Lo-Fi Version | Time is now: 14th May 2024 - 10:51 AM |
