Crack, or normal casting? |
74ravenna |
Sep 24 2016, 10:04 AM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
74ravenna |
Sep 25 2016, 04:51 AM
Its the top of the engine where the cylinder head meets the case.
I'm going with casting imperfections. This is my first go around with taking one of these apart and i've never seen the engine clean! Thanks all. Steve |
rgalla9146 |
Sep 25 2016, 05:50 AM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Its the top of the engine where the cylinder head meets the case. I'm going with casting imperfections. This is my first go around with taking one of these apart and i've never seen the engine clean! Thanks all. Steve I agree. Those rise from the surface. A crack would be hollow into the surface. Some of the responses are 'interesting' though ! |
earossi |
Sep 25 2016, 06:27 AM
Member Group: Members Posts: 210 Joined: 8-December 11 From: Chicago, Il Member No.: 13,878 Region Association: Upper MidWest |
Its the top of the engine where the cylinder head meets the case. I'm going with casting imperfections. This is my first go around with taking one of these apart and i've never seen the engine clean! Thanks all. Steve I agree. Those rise from the surface. A crack would be hollow into the surface. Some of the responses are 'interesting' though ! Good discussion. On my computer I can't see the depth of the crack. If it is simply a shrinkage crack, then it should grind out easily with a Dremel tool. But, if it is a through crack, it's a different story. |
Lo-Fi Version | Time is now: 14th May 2024 - 02:26 AM |
