Head Lights, Looking for advice |
Ross |
Sep 26 2016, 07:01 AM
Member Group: Members Posts: 90 Joined: 17-August 16 From: Charlotte, NC Member No.: 20,304 Region Association: South East States |
Hi Guys,
The frog eyes seem to not go up when I pull the head light switch and then pop up and down when I push the light switch in (or off). Sometimes they come up a few minutes after I pull the switch. The head lights do work when they are up... Does this sounds light a head light switch problem?... or could it be something else? I was looking for the part (91461341410) and it seems that no one makes them anymore... and I can only buy used. Any thoughts or experiences with this? Thank you very much... |
NS914 |
Sep 26 2016, 08:19 AM
Member Group: Members Posts: 198 Joined: 9-June 09 From: Dartmouth, Nova Scotia Member No.: 10,455 Region Association: Canada |
Hi Guys, The frog eyes seem to not go up when I pull the head light switch and then pop up and down when I push the light switch in (or off). Sometimes they come up a few minutes after I pull the switch. The head lights do work when they are up... Does this sounds light a head light switch problem?... or could it be something else? I was looking for the part (91461341410) and it seems that no one makes them anymore... and I can only buy used. Any thoughts or experiences with this? Thank you very much... I am into the same thing....neither head light lifts as it should but if I turn the black spindle on the motor, the left light goes up and down on its own...clearly I have some work to do....looking forward to hearing views and or seeing existing threads o this! Grant |
Ross |
Sep 26 2016, 09:28 AM
I am new to the forum... so please forgive if I am not that best at posting yet, but... I am looking at the switch that would replace the one I have (assuming that my problem is the switch). I called the dealership this morning and that part is discontinued. I have seen a few other places that sell them... pretty expensive... I might go to my used part guy here near me and salvage one.
Mikey914 |
Sep 26 2016, 09:52 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
First of all welcome.
These lights are a little more complex than they seem. You have the switch, and relays, as well as the potential for mechanical interference. 1st thing I would do is test the mechanical portion. This can be done by turning the knob on the back of the motor. You can only turn it one way or unscrew it. Just turn through a cycle. Since it seems like it could be a switch if they both come up together, but the last item is the relay that is below the motor on the body. You can still find used switches If you believe it is the switch, post a WTB in the classifieds here, I'm sure someone can hook you up with a known good one. Diagram attached Attached File(s) light.pdf ( 54.66k ) Number of downloads: 38 |
Ross |
Sep 26 2016, 10:13 AM
thanks Mikey, I'll start looking into it
bandjoey |
Sep 26 2016, 10:18 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Another overlooked place is grounds. Old and rusty. Transmission strap all the way up to the headlights all can cause issues. Clean off the lights first to see if it helps.
Lo-Fi Version | Time is now: 28th May 2024 - 10:48 AM |
