My next 914 project !?, Help me out with your Knowledge |
Qarl |
Jun 24 2003, 09:31 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I have a set of brand new plastic fogligh grills from Germany. No chrome, no primer. Just plain plastic. If you're intereted in using them, let me know ASAP. I will need them back in 30 days.
Regards, Karl |
JWest |
Jun 24 2003, 10:08 AM
I like the speaker grill idea. My suggestion is to make the outside look like stock and to modify the inside with some sort of universal mounting pads for the speakers.
JWest |
Jun 24 2003, 10:14 AM
How about chromed plastic Pedrini/Mahle/Fuchs wheel center caps that look just like the always dented metal originals (but with no dents)?
Relay board cover? I've seen them listed new, but maybe you can reinforce them so they don't crack? |
Ferg |
Jun 24 2003, 10:40 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
How about a Saratoga top style clear targa top? I know it would be a big project and that's not what you want right now, but maybe sometime in the future. Or maybe amber or other colors plastic fog light lenses?? Just throwin out ideas (IMG:style_emoticons/default/driving.gif)
Targa |
Jun 24 2003, 12:27 PM
V Member Group: Members Posts: 180 Joined: 26-December 02 From: San Mateo, CA Member No.: 18 |
QUOTE(James Adams @ Jun 24 2003, 08:08 AM) I like the speaker grill idea. My suggestion is to make the outside look like stock and to modify the inside with some sort of universal mounting pads for the speakers. That would be perfect. I bought some new Kenwood 5x7's thinking that they would just "bolt right in" to the speaker grill. Though we all know that it just does not happen that way with the 914. It seems that the problem is that a 5x7 of today's measurements is a lot bigger than the 5x7's that came in the car(on the outside of the speaker). Well my solution was to use two stock mounting holes to secure the speaker to the grill. But for the speaker to fit in that location I had to cut a section out of the top of the box so that some of the speaker housing would stick out. Not the cleanest mod(though you would never see it), but one that has worked well! IMHO speakers mounted in the door plain suck, while the location of the speaker boxes is Perfect! |
kafermeister |
Jun 24 2003, 12:32 PM
Senior Member Group: Members Posts: 778 Joined: 20-January 03 From: Cincinnati/Northern KY Member No.: 174 |
QUOTE(Targa @ Jun 24 2003, 01:27 PM) It seems that the problem is that a 5x7 of today's measurements is a lot bigger than the 5x7's that came in the car(on the outside of the speaker). (IMG:style_emoticons/default/mellow.gif) I thought the original speakers were 4x6. |
Targa |
Jun 24 2003, 12:51 PM
I could be wrong. But I do believe that I pulled out a 5x7. Also, when I ordered these from crutchfield they had the 914 listed as having 5x7's. (IMG:style_emoticons/default/blink.gif)
Jun 24 2003, 06:01 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I think the fuse box covers would be good. They were NLA for a while; not sure if they still are or not. If so....
I also like the center cap idea! Here's one more for ya: Non-foglight grilles. The ones that just have the "slats" all the way across. I think those are NLA. --DD |
jfort |
Jun 24 2003, 06:17 PM
Senior Member Group: Members Posts: 1,135 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
I agree with the sun visors. Used to have the same problem with old 911's. I can't believe someone doesn't make them. They'd make a fortune.
URY914 |
Jun 24 2003, 07:24 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,544 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
What about a replacement shift knob. Mine is cracked around the bottom at the opening. (it is about the only original, untouched part I have in the interior of my car)
Can you still buy them? Make them stock or all black. Paul |
kafermeister |
Jun 24 2003, 08:09 PM
QUOTE(Targa @ Jun 24 2003, 01:51 PM) I could be wrong. But I do believe that I pulled out a 5x7. Also, when I ordered these from crutchfield they had the 914 listed as having 5x7's. (IMG:style_emoticons/default/blink.gif) You're probably right. I haven't measured them in quite a long time. (IMG:style_emoticons/default/huh.gif) |
ClaussStudios |
Jun 25 2003, 08:03 AM
Newbie Group: Members Posts: 27 Joined: 27-April 03 From: Hesperia CA Member No.: 620 |
QUOTE(acox914 @ Jun 24 2003, 07:25 AM) yeah i see what you mean...i need a pair anyway? Hey clauss, whats porsche/hella say about your new lenses? I dont think they could have much to say, they are not exact copies of their lenses, They are my design and numerous things are changed they just happen to fit in their housings ! (IMG:style_emoticons/default/boldblue.gif) |
914guy |
Jun 25 2003, 01:49 PM
Newbie Group: Members Posts: 46 Joined: 11-April 03 From: Fairfax VA Member No.: 561 |
Front targa top seal
Lo-Fi Version | Time is now: 13th May 2024 - 06:09 AM |
