WTB drivers side foglights grille for 73., And some other little bits! |
Lowsquire |
Sep 28 2016, 07:31 AM
Newbie Group: Members Posts: 20 Joined: 23-April 16 From: Austin Texas Member No.: 19,926 Region Association: Southwest Region |
Hi all,
So my handbrake apparently doesn't hold my car on our steep driveway!feel pretty dumb right now. Got up to find my car at the bottom of the drive against a fence, luckily only damage was a broken grille, drivers side. Any condition chrome okay, as long as it's intact, I'll blast and refinish it. Also looking for 4 alloy porsche lug nuts, suit 5 stud Fuchs . My car had lock nuts on imperial studs when I got it, replaced the studs with metric and just need some standard nuts. Also after a pass. Side headlight cover, the white-ish plastic thing you see with the lights up. If someone had all this stuff I'd be stoked!! Thanks! Ben |
gcrotvik |
Sep 28 2016, 07:41 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
You should re-post in the FS/WTB: 914 Parts section. Maybe an Admin will move this?
GaroldShaffer |
Sep 28 2016, 09:54 AM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Hi all, So my handbrake apparently doesn't hold my car on our steep driveway!feel pretty dumb right now. Got up to find my car at the bottom of the drive against a fence, luckily only damage was a broken grille, drivers side. Any condition chrome okay, as long as it's intact, I'll blast and refinish it. Also looking for 4 alloy porsche lug nuts, suit 5 stud Fuchs . My car had lock nuts on imperial studs when I got it, replaced the studs with metric and just need some standard nuts. Also after a pass. Side headlight cover, the white-ish plastic thing you see with the lights up. If someone had all this stuff I'd be stoked!! Thanks! Ben PM sent for the fog grill |
stugray |
Sep 28 2016, 04:06 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I have both the headlight cover and the foglamp grill.
Lo-Fi Version | Time is now: 5th May 2024 - 11:43 AM |
