WTB: 2.0 AAR 1973, 0 280 140 007 |
Mblizzard |
Sep 29 2016, 08:10 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I am just having no luck with these things. I have purchased a few that have worked to some degree but have ultimately failed in the end!
One that works please. |
euro911 |
Sep 29 2016, 04:56 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Mike, drop the port end of the AAR into a small soup can (or similar vessel) and pour in enough solvent to fill the ports. Let it soak for a day or two, then apply a 12v power source to see if you can get the plunger moving. Repeat the process a few times and it should be good to go. The cleaner you can get it, the better.
MikeInMunich |
Oct 2 2016, 01:29 PM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Mike, drop the port end of the AAR into a small soup can (or similar vessel) and pour in enough solvent to fill the ports. Let it soak for a day or two, then apply a 12v power source to see if you can get the plunger moving. Repeat the process a few times and it should be good to go. The cleaner you can get it, the better. Hmm. Where have I read this recently? (IMG:style_emoticons/default/idea.gif) Good luck! I'm still working on mine. Results still inconclusive at this point. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:09 PM |
