914-6 front hub thickness |
amfab |
Sep 29 2016, 09:30 PM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
Are they 47mm?
Im doing a conversion and wanna get the track right. I assume the hub thickness changes how far the wheels stick out—is this correct? Should I even worry about this? Thanks -Andrew |
Luke M |
Sep 30 2016, 02:00 PM
Senior Member Group: Members Posts: 1,371 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Check the link... Keep in mind that the 930/911 turbo has a wider track.
74 to 89 911 front hubs are the better ones to use. http://www.914world.com/bbs2/index.php?showtopic=286554 |
amfab |
Sep 30 2016, 02:32 PM
Check the link... Keep in mind that the 930/911 turbo has a wider track. 74 to 89 911 front hubs are the better ones to use. http://www.914world.com/bbs2/index.php?showtopic=286554 Hi Luke, Thanks for the link. I am looking to go with 3in spacing struts, M calipers (or maybe Brembos), and 20mm Disks to keep the weight down. I was just curious if the 40mm or even 32mm hubs would be a better choice than the 47mm with regards to fender clearance or other issues. The 47mm hubs are easy to find so if they are ok to use I will just pick up a pair. -Andrew |
Lo-Fi Version | Time is now: 12th May 2024 - 09:07 AM |
