Vacuum Hose question, part looks homemade..what should be there ? |
Frankvw |
Sep 30 2016, 11:32 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Hi all, working on the vacuumhoses check to see what needs to be replaced.
Most are not real Vacuumhose to start with, so I should replace them anyway. I have a question about a part in the vacuumhoses spaghetti It is a 1.7 1973 Question is about the marked splitter: to give you an idea where it is located: This part looks homemade to me and I am not sure if it should be there. If I check on http://www.pelicanparts.com/914/technical_...4_17FI_diag.htm I do not see any hose split in two or three...... Question : what should be there ? Thanks for your help. |
stinkindiesel |
Sep 30 2016, 01:43 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
My car is just like that. Spent a while looking for that part, but never had any luck. I'm currently rocking the "home made" version as well. I've never been clear when or why this was done, as it doesn't seem to match other 1973 vacuum routing I've seen.
My car is a bit of a bastard with a non-original engine, so I can't comment on the originality. Gary |
Lo-Fi Version | Time is now: 12th May 2024 - 02:51 AM |
