Vacuum Hose question, part looks homemade..what should be there ? |
Frankvw |
Sep 30 2016, 11:32 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Hi all, working on the vacuumhoses check to see what needs to be replaced.
Most are not real Vacuumhose to start with, so I should replace them anyway. I have a question about a part in the vacuumhoses spaghetti It is a 1.7 1973 Question is about the marked splitter: to give you an idea where it is located: This part looks homemade to me and I am not sure if it should be there. If I check on http://www.pelicanparts.com/914/technical_...4_17FI_diag.htm I do not see any hose split in two or three...... Question : what should be there ? Thanks for your help. |
stinkindiesel |
Oct 3 2016, 12:34 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
Note that 022133083D is NOT what you want. Wrong size. I see several people are advertising they have the 022133083, but I don't believe they have stock. I tried to order one from Bus Depot last year, and it sat on back order for 6 months before I cancelled the order. I may tweak them again to see if they found a source.
I noticed AA is advertising they are waiting for a new vendor to tool up. Pelicanparts also shows it in the catalog, but the price listed is blank, and I don't believe they can really get it. Sounds like another opportunity for Mike @ 914rubber. Gary |
Lo-Fi Version | Time is now: 11th May 2024 - 02:00 AM |
