lighting problems |
lighting problems |
Schnell944 |
Jun 23 2003, 06:56 PM
Member Group: Members Posts: 121 Joined: 4-January 03 Member No.: 86 |
just installed a new turn signal relay today. it works now, but the lights that are supposed to blik light up very dimly, but if i leave the blinker on and turn the car off, all the lights on that side light up like they should when u forget to cancel the blinker. when i do this, they light up brightly. also my hazard switch isnt working now, and it was b4 i installed the relay. i took the stem off the hazard switch the previous day and the switch fell behind there.....could that have shorted out? and info appreciated. i should be able to register and DRIVE the damn thing once i get these little electrical gremlins fixed.
Schnell944 |
Jun 24 2003, 03:11 PM
anyone have any ideas on what the problem might be?...i think i originally posted this at a bad hour or something
Jun 24 2003, 05:55 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
A wire is mis-connected somewhere in the turn signal circuit. Or you have the wrong type of bulb in one of your light sockets. (The front turn signals use dual-filament bulbs, the rear brake lights likewise; if you use single-filament bulbs in them all kinds of weirdness will happen to you!)
Those are my two best guesses. A good thorough stare at the wiring diagrams, and a nice $20 Rat Shack multimeter, should at least let you start on tracking it down. --DD |
Schnell944 |
Jun 25 2003, 04:24 PM
argh, I hate electrical problems. i dont have a good record at solving them, lol
Schnell944 |
Jun 26 2003, 07:09 PM
ok, question: are the tiny bulbs all the way at the end on the right and left of the light clusters in the rear supposed to be dual filiments? I replaced them w/ the same bulbs that were there when I got the car....were they wrong in the first place? thanks.
Alexlitov |
Jun 26 2003, 10:47 PM
Newbie Group: Members Posts: 41 Joined: 26-April 03 From: San Leandro, CA Member No.: 615 |
check all your connections. maybe you have a loose wire or something. also it's a good idea to clean up the contacts. (IMG:style_emoticons/default/idea.gif)
Lo-Fi Version | Time is now: 13th May 2024 - 12:13 AM |
