MicroSquit Conversion, Giving this a try |
crash914 |
May 22 2017, 04:01 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
You most likely will need to adjust your fuel pressure. Stock D-jet systems used 2 bar fuel pressure. If you look at your flow sheet, minimum flow was 3 bar. This might not make any difference, except for the flow pattern of the spray at 2 bar. (Volume however, is completely different and will require tuning after any change)
Mblizzard |
May 22 2017, 06:17 AM
You most likely will need to adjust your fuel pressure. Stock D-jet systems used 2 bar fuel pressure. If you look at your flow sheet, minimum flow was 3 bar. This might not make any difference, except for the flow pattern of the spray at 2 bar. (Volume however, is completely different and will require tuning after any change) Yep already adjusted. It seems like the stock fuel pressure regulator tops out at about 50 lbs. I am at about 43 lbs. now so I will used that as the starting point. Also you get some good info for programing the fuel set up regarding dead times. Not sure how much difference it makes but the software suggested a dead time of 0.9 ms at 13.2 volts. Looks like I have 0.622 ms. |
Mblizzard |
May 22 2017, 01:52 PM
VW Passat idle air control valve for cold starts. Hopefully better than the 40 year old Auxiliary air valve. At this one can be controlled. This is exactly what I need to add for my car. Zach Got it for $28 off evil bay. I can get you the link. Here is the Link. |
VaccaRabite |
May 25 2017, 10:53 AM
En Garde! Group: Admin Posts: 13,437 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
VW Passat idle air control valve for cold starts. Hopefully better than the 40 year old Auxiliary air valve. At this one can be controlled. This is exactly what I need to add for my car. Zach Got it for $28 off evil bay. I can get you the link. Thanks! Zach |
Mblizzard |
May 25 2017, 07:45 PM
Not a lot of progress. Checking wires and settings. Hope tô Starr this weekend.
VaccaRabite |
May 26 2017, 07:04 AM
VW Passat idle air control valve for cold starts. Hopefully better than the 40 year old Auxiliary air valve. At this one can be controlled. This is exactly what I need to add for my car. Zach Got it for $28 off evil bay. I can get you the link. Thanks Zach Does the connector on your IAC have only 2 prongs and 2 wires or 3 prongs and you only used 2 wires? Zach |
Mblizzard |
May 26 2017, 09:00 AM
VW Passat idle air control valve for cold starts. Hopefully better than the 40 year old Auxiliary air valve. At this one can be controlled. This is exactly what I need to add for my car. Zach Got it for $28 off evil bay. I can get you the link. Thanks Zach Does the connector on your IAC have only 2 prongs and 2 wires or 3 prongs and you only used 2 wires? Zach It is a 2 wire. Forgot to buy the connector so I had to make one. Seems to work well using the PWM method. I have just verified the operation and have not verified the settings required to keep the car running. |
Mblizzard |
May 27 2017, 07:22 PM
Well so close yet nothing. Seems like I have about everything wired up but can't get it to run. Seems like somehow I am failing to be able to trigger the injectors off the coil. No fuel!
Stumped at this point. |
McMark |
May 28 2017, 07:21 AM
Triggering off the coil sucks. (IMG:style_emoticons/default/sad.gif)
Mblizzard |
May 28 2017, 08:19 PM
Ok had is give up on the coil trigger. (IMG:style_emoticons/default/sheeplove.gif)
But I have a 123 electronic dizzy with electronic trigger points. So I thought why not pull a signal off of the electronic points. So I removed all of the coil set up and used the VR channel to pick up a tach signal. And it worked. So it is not perfect as I just used the basic trigger method and I think I have some adjustments to do to smooth it out. But it started and runs. (IMG:style_emoticons/default/piratenanner.gif) Running rich and erratic on the tach signal but running. Any thoughts on the tigger angle offset! I thin that the tach is reading high as it may be seeing double the pluses at the dizzy as it would see at the crank. |
McMark |
May 29 2017, 06:04 AM
The offset angle won't really matter while you're not controlling ignition with the MS. Injector spray timing isn't anywhere close to critical. If it's a few milliseconds off the fuel will essentially just wait in the port for the valve to open.
So the electronic points is essentially a TDC trigger, but it doesn't matter if TDC in reality is sync'd with TDC in the computer. That's what offset angle is for, to fine tune (or sync) the computer and the engine. When you're controlling ignition from the MS, it's crititcally important that TDC be in sync, so when the computer is trying to provide 12degrees of advance, that's actually happening at 12 degrees BTDC. Fuel doesn't really care. But if you ever try to run ignition, none of this will work. |
Mblizzard |
May 29 2017, 10:34 AM
The offset angle won't really matter while you're not controlling ignition with the MS. Injector spray timing isn't anywhere close to critical. If it's a few milliseconds off the fuel will essentially just wait in the port for the valve to open. So the electronic points is essentially a TDC trigger, but it doesn't matter if TDC in reality is sync'd with TDC in the computer. That's what offset angle is for, to fine tune (or sync) the computer and the engine. When you're controlling ignition from the MS, it's crititcally important that TDC be in sync, so when the computer is trying to provide 12degrees of advance, that's actually happening at 12 degrees BTDC. Fuel doesn't really care. But if you ever try to run ignition, none of this will work. Seem to be getting double,tach signal out of trigger points. Any way tom1/2 that in the software. |
McMark |
May 29 2017, 01:50 PM
Check the dual/multi spark options under ignition. You might have luck setting it to Single Cam Wheel Input.
Mblizzard |
May 29 2017, 06:10 PM
VaccaRabite |
May 29 2017, 09:53 PM
Did you ever hardwire the bluetooth adapter in? How are you powering it, since the Microsquirt serial cable does not send power?
Zach |
McMark |
May 30 2017, 06:53 AM
I am using Tunner Studios and don't see this option. It's under the Ignition Setup -> Dual/Multi Spark Options. You are running the MicroSquirt firmware, right? MSII firmware has different menus. As a back up get me a quote for a trigger wheel and sensor as I am tired of screwing with this. A VR/Hall sensor and toothed wheel is the only way to go, whether it's my setup, Mario's setup, or homemade. Reliable RPM is necessary to correctly calculate fuel demands and if you ever want to run ignition is absolutely necessary. http://www.914world.com/bbs2/index.php?showtopic=97550 |
Mblizzard |
May 30 2017, 08:29 AM
Mblizzard |
May 30 2017, 08:34 AM
I am using Tunner Studios and don't see this option. It's under the Ignition Setup -> Dual/Multi Spark Options. You are running the MicroSquirt firmware, right? MSII firmware has different menus. As a back up get me a quote for a trigger wheel and sensor as I am tired of screwing with this. A VR/Hall sensor and toothed wheel is the only way to go, whether it's my setup, Mario's setup, or homemade. Reliable RPM is necessary to correctly calculate fuel demands and if you ever want to run ignition is absolutely necessary. http://www.914world.com/bbs2/index.php?showtopic=97550 Well taking this approach will require an engine drop (IMG:style_emoticons/default/headbang.gif) Not what I want to do. There has to be some way to make this coil approach work. Going to work with the coil a bit more to see if I can get something working. What I really need is a way to get the trigger point signal into the ECU. |
McMark |
May 30 2017, 09:25 AM
Mblizzard |
May 30 2017, 09:31 AM
Lo-Fi Version | Time is now: 3rd May 2024 - 10:13 PM |
