WTB: ignition connector, this is a '75 |
malcolm2 |
Oct 3 2016, 08:07 AM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Looking to cut the bad stuff out of the end of the wires for the ignition. Figured I would try to find a new connection block too.
I bet they are NLA, or maybe never available. Anyone have spares for sale? IIRC: Kinda looks like a VW MK1 might work? Clark |
bdstone914 |
Oct 3 2016, 10:03 AM
I have a wire harness for parts that I should have one for harvesting. Can check when I am home in a couple of days it you do not find one sooner.
malcolm2 |
Oct 3 2016, 10:04 AM
JeffBowlsby |
Oct 3 2016, 03:05 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Is yours melted or significantly damaged? They rarely are a problem.
malcolm2 |
Oct 3 2016, 05:26 PM
Is yours melted or significantly damaged? They rarely are a problem. I have not pulled the wires, but it does not appear to be damaged. Can't tell about the connectors either. You are probably right, but before i start cutting, I would be more comfortable having a spare in my pocket. During my search today, I read where some VW guys don't use the block. Just mark the wires and use the markings on the switch or match them to the block. So there is a back-up option. EDIT: Turns out AA sells them. Not easy to find, but they are listed and on an exploded view drawing. Less than $10 IIRC. |
timothy_nd28 |
Oct 3 2016, 07:31 PM
It is melted and significantly damaged.
Lo-Fi Version | Time is now: 19th May 2024 - 09:18 AM |
