Lost exhaust stud, need parts or info on what to buy locally |
Millerwelds |
Oct 5 2016, 12:00 PM
Pleepleus Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California |
Lost an exhaust stud on my 74 2.0. Need a new stud and washer/nut.
Any concern driving it with missing stud? |
N_Jay |
Oct 5 2016, 12:09 PM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
If it is leaking you can burn the head and heat exchanger.
porschetub |
Oct 5 2016, 01:07 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
You could just put a bolt in there till you get a new stud (IMG:style_emoticons/default/biggrin.gif)
Mark Henry |
Oct 5 2016, 01:12 PM
Stud pulled right out? If it did consider yourself lucky...better than a broken stud. (IMG:style_emoticons/default/smile.gif)
You have to fix it right, 8mm/9mm step stud or a timesert. |
Elliot Cannon |
Oct 5 2016, 01:23 PM
I have some spares. I'll send one to you if you need it.
Millerwelds |
Oct 5 2016, 02:24 PM
Stud pulled right out? If it did consider yourself lucky...better than a broken stud. (IMG:style_emoticons/default/smile.gif) You have to fix it right, 8mm/9mm step stud or a timesert. No, it loosened up, unscrewed itself out and disappeared... |
Millerwelds |
Oct 5 2016, 02:38 PM
You could just put a bolt in there till you get a new stud (IMG:style_emoticons/default/biggrin.gif) Any ideas what size bolt would work. It has euro headers instead of heat exchangers if that matters |
Mark Henry |
Oct 5 2016, 03:37 PM
Stud pulled right out? If it did consider yourself lucky...better than a broken stud. (IMG:style_emoticons/default/smile.gif) You have to fix it right, 8mm/9mm step stud or a timesert. No, it loosened up, unscrewed itself out and disappeared... Yeh... Hokay, maybe you will take my advice when the replacement falls out. (IMG:style_emoticons/default/biggrin.gif) Studs in aluminum VW heads don't just fall out, the threads are boogered, still enough there to give the illusion all is OK. |
N_Jay |
Oct 5 2016, 03:42 PM
Any hardware store has 8mm hardened bolts, get a long one and cut the head off.
Instant stud, which will prove the threads are stripped. |
injunmort |
Oct 5 2016, 04:03 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
you can get 8mm x 56mm studs at flaps, i think they are for ford explorer. 8 studs and flanged nuts for about $6.00. made by dorman.
Millerwelds |
Oct 5 2016, 04:05 PM
you can get 8mm x 56mm studs at flaps, i think they are for ford explorer. 8 studs and flanged nuts for about $6.00. made by dorman. OK Thanks all. I did get a new stud locally. Will order a stepped stud for when Mark is proven right and I have to do this again in a few weeks..... (IMG:style_emoticons/default/beerchug.gif) |
Tbrown4x4 |
Oct 5 2016, 07:42 PM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Hope I'm not hijacking. My heads have stepped studs installed already. Is it because they came off a 1976 van 2.0? Those stepped studs are $9 each.
Mark Henry |
Oct 5 2016, 09:09 PM
injunmort |
Oct 5 2016, 09:31 PM
what i like about the dorman studs are they are hexed on one end, so you can tighten them in with a socket as as opposed double nutting. that is of course, if the threads are not buggered. i have used these on two engines, so far so good. better than original. if the threads are buggered, all bets are off. got them at my local advanced auto parts store.
veekry9 |
Oct 5 2016, 09:35 PM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
https://www.belmetric.com/8mm-metric-studs-c-9_71/
Say yes to stainless studs. (IMG:style_emoticons/default/smile.gif) / |
Lo-Fi Version | Time is now: 17th May 2024 - 04:33 PM |
