Millerwelds
Oct 5 2016, 12:00 PM
Lost an exhaust stud on my 74 2.0. Need a new stud and washer/nut.
Any concern driving it with missing stud?
N_Jay
Oct 5 2016, 12:09 PM
If it is leaking you can burn the head and heat exchanger.
porschetub
Oct 5 2016, 01:07 PM
You could just put a bolt in there till you get a new stud
Mark Henry
Oct 5 2016, 01:12 PM
Stud pulled right out? If it did consider yourself lucky...better than a broken stud.
You have to fix it right, 8mm/9mm step stud or a timesert.
Elliot Cannon
Oct 5 2016, 01:23 PM
I have some spares. I'll send one to you if you need it.
Millerwelds
Oct 5 2016, 02:24 PM
QUOTE(Mark Henry @ Oct 5 2016, 12:12 PM)
No, it loosened up, unscrewed itself out and disappeared...
Millerwelds
Oct 5 2016, 02:38 PM
QUOTE(porschetub @ Oct 5 2016, 12:07 PM)
Any ideas what size bolt would work. It has euro headers instead of heat exchangers if that matters
Mark Henry
Oct 5 2016, 03:37 PM
QUOTE(Millerwelds @ Oct 5 2016, 04:24 PM)
Yeh... Hokay, maybe you will take my advice when the replacement falls out.
Studs in aluminum VW heads don't just fall out, the threads are boogered, still enough there to give the illusion all is OK.
N_Jay
Oct 5 2016, 03:42 PM
Any hardware store has 8mm hardened bolts, get a long one and cut the head off.
Instant stud, which will prove the threads are stripped.
injunmort
Oct 5 2016, 04:03 PM
you can get 8mm x 56mm studs at flaps, i think they are for ford explorer. 8 studs and flanged nuts for about $6.00. made by dorman.
Millerwelds
Oct 5 2016, 04:05 PM
QUOTE(injunmort @ Oct 5 2016, 03:03 PM)
OK Thanks all. I did get a new stud locally. Will order a stepped stud for when Mark is proven right and I have to do this again in a few weeks.....
Tbrown4x4
Oct 5 2016, 07:42 PM
Hope I'm not hijacking. My heads have stepped studs installed already. Is it because they came off a 1976 van 2.0? Those stepped studs are $9 each.
Mark Henry
Oct 5 2016, 09:09 PM
QUOTE(Tbrown4x4 @ Oct 5 2016, 09:42 PM)
They come standard on new AMC heads, but from the factory it would have been straight 8mm studs.
injunmort
Oct 5 2016, 09:31 PM
what i like about the dorman studs are they are hexed on one end, so you can tighten them in with a socket as as opposed double nutting. that is of course, if the threads are not buggered. i have used these on two engines, so far so good. better than original. if the threads are buggered, all bets are off. got them at my local advanced auto parts store.
veekry9
Oct 5 2016, 09:35 PM
