Too much fuel and fouling the plugs, Checked for broken wires and obvious things |
9fourteen14 |
Oct 7 2016, 03:14 PM
PORSCHE LUVA Group: Members Posts: 135 Joined: 5-July 15 From: boston Member No.: 18,920 Region Association: North East States |
I need help identifying this part.
i have a 74 2.0 teener. djet this part is beside the distributor (that is the orange piece with the clamp) and in front of the coil (the larger green wire.) the green wire from this part has a brown stripe..where does it go? where does the black wire to this part go? I am trying to identify the part but in the long run something is awry. not starting we have checked plugs (which are wet with fuel) we have changed them so there is fuel, a good fuel pump. so right now just seeing what could prevent this from starting and found this part and need to identify it. thanx for all your help. thanx so much will update when figured out the problem. I am sure we just dislodged a wire. stay tuned. 914luva |
9fourteen14 |
Oct 7 2016, 05:47 PM
TOO MUCH FUEL in MY 74 2.0 TEENER
It is fouling the plugs The starter is good The pump is good The AAr is good I have the air filter off. Should start without filter. It is not starting What on earth can it be? Any tip and or suggestions Almost ready to take engine out. In mass and need the rtowle help. After engine out. Rtowle and mass group I will be ready to work with you VERY SOON. PLEASE CONTACT ME ASAP THANX |
Lo-Fi Version | Time is now: 19th May 2024 - 05:45 AM |
