Too much fuel and fouling the plugs, Checked for broken wires and obvious things |
9fourteen14 |
Oct 7 2016, 03:14 PM
PORSCHE LUVA Group: Members Posts: 135 Joined: 5-July 15 From: boston Member No.: 18,920 Region Association: North East States |
I need help identifying this part.
i have a 74 2.0 teener. djet this part is beside the distributor (that is the orange piece with the clamp) and in front of the coil (the larger green wire.) the green wire from this part has a brown stripe..where does it go? where does the black wire to this part go? I am trying to identify the part but in the long run something is awry. not starting we have checked plugs (which are wet with fuel) we have changed them so there is fuel, a good fuel pump. so right now just seeing what could prevent this from starting and found this part and need to identify it. thanx for all your help. thanx so much will update when figured out the problem. I am sure we just dislodged a wire. stay tuned. 914luva |
McMark |
Oct 8 2016, 10:59 AM
CHT failure will make it so rich it won't run.
Intake air temp sensor failure will make it rich, but still run. |
Lo-Fi Version | Time is now: 28th May 2024 - 01:48 AM |
