Solex 40 P11 pair with factory 914, T4 linkage, manifolds, Xlent dash top, Triad header, engines, trans. price drop |
914ltd |
Oct 7 2016, 06:49 PM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
Complete set of factory linkage and 2 solid shaft Solex carbs. This is a type 4 industrial set that used to be required for SCCA E production on a Porsche 914. All in very good condition with good throttle shafts. (solid shaft carbs) Just removed from a 914 that had set for decades. The engine was started before removal. Everything is in great shape although the carbs probably could use rebuild kits. $700.
Also for sale: Triad racing 4 into 1 headers with additional glass pack muffler, modified shift rod and heat shield for clutch cable bracket. Short stub tubes bolt into the heads. Just removed from a racer. ugly from setting but solid. $500. Excellent crack and sag free original late dash top. $400. 1972 "EA" 1.7 engine with fuel injection, runs great, just removed Tuesday. Drop in and drive. $400. 1972 tailshift transaxle, excellent syncros, even 1st gear. Use as in for your early car or easy to convert to sideshift with $100. additional in parts. Removed 10/4/16 $250 2, 2.0 engines with sheetmetal, core for rebuild, $400. each. pick up or truck shipping. Shipping is at my shop cost plus $3. per box I will add additional pictures this weekend. Thanks for looking, Brad Attached image(s) |
RohJay |
Oct 8 2016, 05:54 AM
Member Group: Members Posts: 189 Joined: 24-April 07 From: Colombo, SRI LANKA Member No.: 7,689 |
Interested in the Triad headers. Shall await pictures.
914ltd |
Oct 8 2016, 07:24 PM
Complete set of factory linkage and 2 solid shaft Solex carbs. This is a type 4 industrial set that used to be required for SCCA E production on a Porsche 914. All in very good condition with good throttle shafts. (solid shaft carbs) Just removed from a 914 that had set for decades. The engine was started before removal. Everything is in great shape although the carbs probably could use rebuild kits. $900. Also for sale: Triad racing 4 into 1 headers with additional glass pack muffler, modified shift rod and heat shield for clutch cable bracket. Short stub tubes bolt into the heads. Just removed from a racer. ugly from setting but solid. $600. Crack and sag free original late dash top. $425. 1972 "EA" 1.7 engine with fuel injection, runs great, just removed Tuesday. Drop in and drive. $450. 1972 tailshift transaxle, excellent syncros, even 1st gear. Use as in for your early car or easy to convert to sideshift with $100. additional in parts. Removed 10/4/16 $350 2, 2.0 engines with sheetmetal, core for rebuild, $400. each. pick up or truck shipping. Shipping is at my shop cost plus $3. per box I will add additional pictures this weekend. Thanks for looking, Brad Attached image(s) |
RohJay |
Oct 9 2016, 11:18 AM
Sent PM on Triad headers
audio_file |
Oct 9 2016, 01:17 PM
Member Group: Members Posts: 295 Joined: 6-August 11 From: Everett, Wa Member No.: 13,409 Region Association: Pacific Northwest |
Would you sell the intake "manifolds" separate from the carbs? Price?
Chris |
914ltd |
Oct 20 2016, 06:11 AM
Price drop on everything and all really good parts. I'll need to stack stuff outside if something doesn't sell. |
Lo-Fi Version | Time is now: 15th May 2024 - 06:51 PM |
