Complete set of factory linkage and 2 solid shaft Solex carbs. This is a type 4 industrial set that used to be required for SCCA E production on a Porsche 914. All in very good condition with good throttle shafts. (solid shaft carbs) Just removed from a 914 that had set for decades. The engine was started before removal. Everything is in great shape although the carbs probably could use rebuild kits. $700.
Also for sale: Triad racing 4 into 1 headers with additional glass pack muffler, modified shift rod and heat shield for clutch cable bracket. Short stub tubes bolt into the heads. Just removed from a racer. ugly from setting but solid. $500.
Excellent crack and sag free original late dash top. $400.
1972 "EA" 1.7 engine with fuel injection, runs great, just removed Tuesday. Drop in and drive. $400.
1972 tailshift transaxle, excellent syncros, even 1st gear. Use as in for your early car or easy to convert to sideshift with $100. additional in parts. Removed 10/4/16 $250
2, 2.0 engines with sheetmetal, core for rebuild, $400. each. pick up or truck shipping.
Shipping is at my shop cost plus $3. per box
I will add additional pictures this weekend.
Thanks for looking, Brad
