CV joint gone bad?, Noise while in gear but not when in neutral... |
MikeInMunich |
Oct 13 2016, 01:21 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Greetings from Munich once again! Yet another issue to rectify, I believe...
I hear a "rambling" coming from the passenger side of the car. Thought it was perhaps the hub bearing, but when the car is rolling in neutral it stops. I'm thinking it must be the CV joint bearing. When I go over any small bumps in the road, I've heard a "knocking" and this could have two sources, one of which I eliminated and this distinctive knocking indeed stopped, but while listening for it, I became more attuned to the rambling sound, which I hadn't really noticed until recently. The knocking was apparently coming from my ECU which unfortunately was just lying next to the battery tray, as I have no bracket for it. Now it is properly secured and can't make any noises, YET...this rambling sound seems to also have a slight "knock" in there now and then as well. (IMG:style_emoticons/default/confused24.gif) So that's the description of my symptom, and my question is if y'all think my diagnosis is correct. If so, do I only need to change the CV joint bearings, or are there other parts I should also change along with them? Update: just found, in Google search results, 914 Rubber offering CV joint bolts and a mention of "stop your CV joints from "banging around"" or something like that. So this PS CV joint may just be loose? Thanks a lot for your time, feedback and advice! Mike in Munich |
euro911 |
Oct 13 2016, 02:13 AM
A bad CV joint will make more of a clacking noise under load (accelerating or decelerating).
Yes, I'd check for loose bolts in both the inboard and outboard CV joints first. New bolts are recommended any time the joints are reinstalled, even though a lot of folks don't do it. If they're all torqued to spec, there shouldn't be a problem with them loosening up. You can check for hub bearing wear by jacking up the rear and checking the wheels for up/down or side-to-side movement (wobble). Also, check to assure the rear shock mounting points are tight. Check everything down there, including the brake caliper. Torque everything to spec. I had a noise in the same area and wondered the same thing ... that turned out to be a loose lug bolt, so check there too. |
MikeInMunich |
Oct 13 2016, 03:40 AM
Thanks Mark!
Cracker |
Oct 13 2016, 07:00 AM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Also, check the pivot axle nut - make sure they are appropriately TIGHT. Don't ask me how I came up with this...probably not your issue here but a good thing to double check too! (IMG:style_emoticons/default/blink.gif)
Tony |
bdstone914 |
Oct 13 2016, 07:11 AM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have not heard the.CV bolts should be replaced but the Schnoor washers are a one time use ans should be replaced. Bolts need to be clean and free of grease. One good tip to know if they are backing out id put a dap of nail polish on the bottom edge of the bolt and flange. If the pint daps do not line up they are backing out.
76-914 |
Oct 13 2016, 09:01 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Grab the half shaft in hand and slide it back and forth with force. Do you hear your clunking noise. If so, you've a bad CV. (IMG:style_emoticons/default/beerchug.gif)
MikeInMunich |
Oct 13 2016, 11:29 AM
Thanks gentlemen,
I was under there today and each of the inside bolts on both sides took between 3 and 8 quarter turns with the ratchet. (IMG:style_emoticons/default/blink.gif) The outside ones were all tight. The sound does seem to be less than it was yesterday, but also doesn't seem to be completely gone either. I will check for that wiggle / clunk by trying to shake the axel tomorrow. The wheel bearings seem to be tight. I'm not clear on where this pivot axel nut is. ?? M.i.M. |
Cracker |
Oct 13 2016, 12:03 PM
Your's might be but "seems to be tight" = they may not be too. Have someone hold the brakes and with an extension bar at least 3 feet long tighten the spindle nut. 250 ft lbs. My snap-on impact doesn't have enough power. Had to do it manually to get it tight enough.
Regarding the pivot axle nut...there are two. The front of the trailing arm rotates on the pivot axle - nuts on both sides keep it in place and place pressure on the bushings.. They can loosen over time, re-torque. Tony The wheel bearings seem to be tight. I'm not clear on where this pivot axel nut is. ?? M.i.M. |
euro911 |
Oct 13 2016, 12:17 PM
MikeInMunich |
Oct 14 2016, 12:23 AM
Also, check the pivot axle nut - make sure they are appropriately TIGHT. Don't ask me how I came up with this...probably not your issue here but a good thing to double check too! (IMG:style_emoticons/default/blink.gif) Tony Can you please let me know which is the axel pivot nut in this photo? Thanks a lot! M.i.M. |
euro911 |
Oct 14 2016, 02:44 AM
#24 and #29, on each side of the pivot shaft, at the front of the trailing arm(s)
MikeInMunich |
Oct 14 2016, 03:19 AM
MikeInMunich |
Jan 21 2017, 01:57 AM
Update: I originally posted about a mysterious, occasional "clunk". Not sure if i mentioned this in the original post but I suspect edit was the CPU as it's not attached to the battery tray.
Well, the car was at a local shop here near Munich to change the ignition switch and they checked everything mentioned here and even pulled the CV joints and regressed them. When I picked the car up a noise apparently coming from the CV joint, apparently more so from the passenger's side of the car, was Lou der than it was when I brought them the car. This noise, which I may or may mit have mentioned already above, isn't loud but consistent and kinda like a rrrrrrrrrr sound, which decreases in volume noticeably when I step on the clutch. Time to change the CV joints out, soon? Your thoughts and time are much appreciated! Thanks a lot! (IMG:style_emoticons/default/beerchug.gif) Mike in Munich (IMG:style_emoticons/default/smilie_flagge6.gif) P.S. Germany was just ranked the best country in the world again, by the Economist, and most news about the refugee crises makes the situation over here sound like the country is in a virtual state of chaos, which isn't remotely close to the case whatsoever. Come visit! |
euro911 |
Jan 21 2017, 02:15 AM
If the 'rrrrr' noise goes away when you depress the clutch pedal, I wonder if it's your throw-out bearing (or 'release bearing' as some call them)?
MikeInMunich |
Jan 21 2017, 04:55 AM
hmmm. Thanks for the suggestion. I'll have to consider that.
Lo-Fi Version | Time is now: 15th May 2024 - 11:25 AM |
