Greetings from Munich once again! Yet another issue to rectify, I believe...
I hear a "rambling" coming from the passenger side of the car. Thought it was perhaps the hub bearing, but when the car is rolling in neutral it stops. I'm thinking it must be the CV joint bearing. When I go over any small bumps in the road, I've heard a "knocking" and this could have two sources, one of which I eliminated and this distinctive knocking indeed stopped, but while listening for it, I became more attuned to the rambling sound, which I hadn't really noticed until recently. The knocking was apparently coming from my ECU which unfortunately was just lying next to the battery tray, as I have no bracket for it. Now it is properly secured and can't make any noises, YET...this rambling sound seems to also have a slight "knock" in there now and then as well.
So that's the description of my symptom, and my question is if y'all think my diagnosis is correct. If so, do I only need to change the CV joint bearings, or are there other parts I should also change along with them?
Update: just found, in Google search results, 914 Rubber offering CV joint bolts and a mention of "stop your CV joints from "banging around"" or something like that. So this PS CV joint may just be loose?
Thanks a lot for your time, feedback and advice!
Mike in Munich
