How to remove steering Lock |
Phoenix-MN |
Oct 18 2016, 02:30 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
I'm trying to remove the steering lock from the ignition housing. I have the key lock removed and the switch removed. Cannot figure out how to get the column lock out??? Is the plastic piece staked into the housing?
Thanks |
whitetwinturbo |
Oct 18 2016, 09:40 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
Cairo94507 |
Oct 19 2016, 06:22 AM
Michael Group: Members Posts: 9,745 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I would look up Tweet on our site. He is a lock genius and understands all of these parts and how they work. He restores locks for our cars.
Phoenix-MN |
Oct 19 2016, 06:53 AM
bdstone914 |
Oct 19 2016, 07:26 AM
bdstone914 Group: Members Posts: 4,517 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Remove the set scrrw on the side of the housing abd it pulls out.
Phoenix-MN |
Oct 19 2016, 08:47 AM
malcolm2 |
Oct 19 2016, 08:50 AM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Remove the set scrrw on the side of the housing abd it pulls out. isn't the set screw for the switch? there is a set screw for the switch. it is visible when you remove the wiring block that connects to the switch. It is very small and down in that hole. |
Phoenix-MN |
Oct 19 2016, 10:09 AM
OK guys (IMG:style_emoticons/default/dry.gif) as said in the original post, I have the switch and set screw removed and the key lock removed. The set screw does not hold the plastic piece in housing, it is staked with two small punches on each side of the housing. I opened the stakes out with a very small chisel and then the plastic piece just slid out.
tweet |
Jan 9 2017, 10:07 PM
Member Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
Okay, that steering lock housing may be toast, they are not supposed to be disassembled like that. The tiny set screw is for the purpose of holding in and orienting/positioning the electrical switch. The ignition lock can be released by depressing the spring clip through the small access hole. If you are still having trouble with it, I can help. Shoot me a pm.
Lo-Fi Version | Time is now: 11th May 2024 - 08:05 PM |
