Dads new car |
Dads new car |
mb911 |
Oct 19 2016, 02:29 PM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
My dad is getting his new car today.. Its a 74 2.0 pretty rust free car.. He has had about 10 Porsches over the year s and currently has an 02 boxster s with about 40k on it but needed a retirement project.. Dad is approaching 70 so this a longer term project but it should be fun.. The price was right as he got it for free although I have to provide labor on a 2.2 E rebuild.. I still think it was a good buy
mb911 |
Aug 30 2017, 02:02 PM
So just a quick update.. Dad has confirmed it is a 2.0 and has wire brushed the floors top to bottom and then primed them with red oxide. He has cleaned all grounds and put plugs in it after soaking the cylinders with fogging oil .. Fuel tank is in and clean though he is missing the retaining strap and one of the rubber chunk that centers the tank. New fuel filter etc..
Bad news engine seems locked up.. Any tips for a better solution to free the rings?? He is pulling starter to see if he can spin the flywheel.. I am thinking engine has to come out.. Any thoughts as dad is pretty stubborn but any tips I can give will help. |
mepstein |
Aug 30 2017, 03:05 PM
914-6 GT in waiting Group: Members Posts: 19,274 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
So just a quick update.. Dad has confirmed it is a 2.0 and has wire brushed the floors top to bottom and then primed them with red oxide. He has cleaned all grounds and put plugs in it after soaking the cylinders with fogging oil .. Fuel tank is in and clean though he is missing the retaining strap and one of the rubber chunk that centers the tank. New fuel filter etc.. Bad news engine seems locked up.. Any tips for a better solution to free the rings?? He is pulling starter to see if he can spin the flywheel.. I am thinking engine has to come out.. Any thoughts as dad is pretty stubborn but any tips I can give will help. Ben - I have the tank rubber and straps whenever you want them. Make up a list and I'll send it over. |
mb911 |
Aug 30 2017, 03:18 PM
So just a quick update.. Dad has confirmed it is a 2.0 and has wire brushed the floors top to bottom and then primed them with red oxide. He has cleaned all grounds and put plugs in it after soaking the cylinders with fogging oil .. Fuel tank is in and clean though he is missing the retaining strap and one of the rubber chunk that centers the tank. New fuel filter etc.. Bad news engine seems locked up.. Any tips for a better solution to free the rings?? He is pulling starter to see if he can spin the flywheel.. I am thinking engine has to come out.. Any thoughts as dad is pretty stubborn but any tips I can give will help. Ben - I have the tank rubber and straps whenever you want them. Make up a list and I'll send it over. Sounds good. He also needs a 2.0 muffler not picky just anything.. |
Lo-Fi Version | Time is now: 18th May 2024 - 09:40 PM |
