Dads new car |
Dads new car |
mb911 |
Oct 19 2016, 02:29 PM
914 Guru Group: Members Posts: 6,856 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
My dad is getting his new car today.. Its a 74 2.0 pretty rust free car.. He has had about 10 Porsches over the year s and currently has an 02 boxster s with about 40k on it but needed a retirement project.. Dad is approaching 70 so this a longer term project but it should be fun.. The price was right as he got it for free although I have to provide labor on a 2.2 E rebuild.. I still think it was a good buy
ClayPerrine |
Jun 22 2018, 04:58 PM
Life's been good to me so far..... Group: Admin Posts: 15,483 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I would suggest unplugging the ignition switch. Then put a test wire into the yellow wire on the ignition switch plug. Hook that to the remote starter button, and the other side to the positive battery terminal. See if it cranks.
If it does, then the wire between the ignition switch and the starter is good. If that works, then remove the remote starter button from the battery and connect it to the heavy red wire on the starter switch plug. If it cranks, replace the electrical portion of the ignition switch. I have seen lots of them fail, so that is probably the problem. |
Lo-Fi Version | Time is now: 26th May 2024 - 09:57 AM |
