Falken Azenis tires on Fuchs, 205X50? |
skline |
Apr 19 2005, 09:23 PM
Can you run Falken Azenis tires on 2 liter Fuch alloys? Will they clear the wheel well without flaring? The wheels I picked up last weekend turned out to not be 15X6. They are the same size and offset as the 2 liter Fuch alloys I already have on the car. So what are you running with these tires? Not Aaron as he is running 5 lug.
Aaron Cox |
Apr 19 2005, 09:37 PM
lots of people run them on 5.5 inch rims.... 6 is better 7 is Recommened
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
rhodyguy |
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,076 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
205/50/15 potenza. i can't imagine the cross section is too much different. oe 4 lug fuch. tiny rub at full lock. i can still run my fingers in between the tire and the lip on the rear. your experience may vary?
k |
grantsfo |
Apr 19 2005, 09:41 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
I ran 205/50/15 Falkens on my 5.5 Fuchs and they fit great. Just make sure to run pressures over 36 PSI or they get sloppy.
hmeeder |
Apr 19 2005, 09:57 PM
Dante's Sportscar Group: Members Posts: 352 Joined: 21-November 04 From: San Diego, CA Member No.: 3,154 |
Scott;
I know several people that run the Azenis on Fuchs and other Porsche wheels (as I do) and I don't know of any clearance issues. Though I would have to disagree with Grant. On the street I run them at 32 and when Autocrossing I start those tires at 25 lbs cold and tweak the pressure from there depending on the track conditions and layout. When I was instructing at our regions' most recent driving school 2 weeks ago I ran the tires at 32 lbs. I was feeling lazy and had left them at the pressure I run them on the street. I found them to be squirrely and I was skating around like Dorothy Hammel on speed (anyone says that 914s can't spin a 360 aren't trying hard enough!) I know people differ greatly on tire pressure so that's just me. |
Dave-O |
Apr 19 2005, 09:59 PM
Is winter done yet? Group: Members Posts: 511 Joined: 26-August 03 From: Minneapols, MN Member No.: 1,082 |
yep,
David Attached image(s) |
MattR |
Apr 19 2005, 10:09 PM
Scott, I dont know for sure, but logic tells me to stick with 195s on 5.5" wheels. Its possible you end up decreasing your sidewall stiffness to the point where the extra 10mm you would gain by running a 205 vs a 195 is lost.
The azines RT-615s are out now. They have a 195 50 15 tire that would be killer for autox. It doesnt show in stock at vulcan tire, but I bet if you search around you can find a set. |
skline |
Apr 19 2005, 11:23 PM
Well, they are on their way here so I will know in just a little while.
Aaron Cox |
Apr 19 2005, 11:27 PM
195's or 205's? rt 215 or 615s? 195 50's would be even shorter then a 205 50 (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) way fun |
MattR |
Apr 19 2005, 11:42 PM
Perfecto for autox. Imagine the 195 50 15s with his already torquey 2l... geesh. Slap on some paint and you got yourself a real race car! |
skline |
Apr 20 2005, 12:05 AM
They are 205's and they are the newer ones and it has paint on it, it's just grey and not shiny. Too much to do and not enough time in a week. |
Aaron Cox |
Apr 20 2005, 12:12 AM
RT-615's i assume.... very cool.... they will have some serious sidewall bulge.... but thats due to a 5.5 inch rim.... my 6" rims make them have a subtle bulge... |
MattR |
Apr 20 2005, 12:31 AM
My 7s are perfect for the wheel, but not my fender... (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif)
its primer not paint. these are porsches, not camaros (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) I wish i had some time to help you out scott. Maybe tomorrow i can run down and help you sand for a little bit? I'm off at 1pm. |
skline |
Apr 20 2005, 12:42 AM
That would be cool, I have work to do until about then anyway. Need to get the hood done and cowl and then change the drivers door again with one that is all together to same some time. Plus I need to get the tires mounted and balanced and put them on the car. Lots to do yet. I am also going to pull the interior out of the Chalon and put it in the 2 liter. One seat isnt enough and the rattling would drive me nuts. Then finish installing the stereo and speakers. Could use your help with whatever you could offer.
Apr 20 2005, 01:08 PM
914 Idiot Group: Members Posts: 14,983 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Sort of. I mean, the extra torque is nice, and the feedback from the contact patch is just fabulous. But you better get used to shifting!! 2-3-2-3-2-3-2-3-2-3... I feel like I row the damn car sometimes!!! Sometimes you get killed because the more important parts of the course are in between gears for you, so you have to upshift and downshift while your competitors just hold the lower gear. Doesn't seem to happen all that often, but it does happen. Herb writes:
Heck, you can do multiple 360s (at least one in each direction!) even without trying, sometimes! I was pegged at the top of 3rd gear and lost the back end of the car (whoops, forgot the last slalom cone was shorter than the rest!). Went round and round and round... I tried to catch it a couple of times, but that just sent me around the other way. I wound up doing at least 3 360s. Thank heaven Alameda has tons of run-off room. --DD |
Lo-Fi Version | Time is now: 10th May 2024 - 11:28 PM |
