Replacement for center console clock...that works. |
carcus |
Oct 22 2016, 01:47 AM
Member Group: Members Posts: 223 Joined: 16-March 16 From: Colorado Springs Member No.: 19,760 Region Association: Rocky Mountains |
I have the OEM center console clock, but it does not work, just lights up. I know they were Quartz, but do not know if they have a battery that I can open up the clock and replace. Is there a more modern clock that will match the car aftermarket in the same spot that looks VDO? I do not want to spend a ton of money for a clock in an old car...I think you guys get that.
dlkawashima |
Oct 22 2016, 02:00 AM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
I encourage you to try to fix it yourself, especially if you have a Type I clock. Follow the directions here:
http://www.pelicanparts.com/techarticles/m...lock_repair.htm |
Ian Stott |
Oct 22 2016, 04:39 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Is there a vendor where you can send it for repair?
Ian Stott Moncton Canada |
GeorgeRud |
Oct 22 2016, 08:52 AM
North Hollywood Speedometer does excellent work (though not always considered cheap).
914Sixer |
Oct 22 2016, 08:50 PM
914 Guru Group: Members Posts: 8,875 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I have a NOS Audi movement that is a direct fit. I would recommend that you send it to NHS for replacement because it requires a SPECIAL LOW TEMPERATURE solider. Picture on request.
carcus |
Oct 22 2016, 09:55 PM
Thanks for the great info and repair link. I need to do some research to find out if it is a type 1 or later type 2 VDO clock. I got the appearance console second hand and added the gauges. Not sure what year 914 they came out of.
Lo-Fi Version | Time is now: 5th May 2024 - 04:22 AM |
