Door Lock Mechanism, Help |
mmascari |
Oct 25 2016, 08:06 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
Can someone take a look at my door mechanism and tell me if it is missing a spring or something? The latch portion on the back is loose and I think it is supposed to be more firm. I apologize for the greasy photo. The door doesn't close correctly.
jim_hoyland |
Oct 25 2016, 08:16 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Yup: the spring is missing. And it different than regular springs. The ends are flat. Put an add in the classified; someone will have one.
I cleaned my mechanism w in the brake-cleanet solvent and a small acid brush. After it's super clean lube with PB Dry Teflon spray ( sold at Home Depot next to the PB Blaster) Attached image(s) |
mmascari |
Oct 25 2016, 08:37 PM
Thanks Jim....I figured as much. Thanks for the advice on cleaning and lubricant
steuspeed |
Oct 25 2016, 08:45 PM
Senior Member Group: Members Posts: 1,006 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Sticky mechanism will lead to broken door handles. Definitely clean and lube that.
jim_hoyland |
Oct 25 2016, 09:15 PM
Your old spring may be in the bottom of the door
Pics Attached image(s) |
mmascari |
Oct 25 2016, 09:19 PM
I guess I will hit Parts Heaven tomorrow to get a spring.
Lo-Fi Version | Time is now: 18th May 2024 - 09:46 PM |
