mmascari
Oct 25 2016, 08:06 PM
Can someone take a look at my door mechanism and tell me if it is missing a spring or something? The latch portion on the back is loose and I think it is supposed to be more firm. I apologize for the greasy photo. The door doesn't close correctly.
jim_hoyland
Oct 25 2016, 08:16 PM
Yup: the spring is missing. And it different than regular springs. The ends are flat. Put an add in the classified; someone will have one.
I cleaned my mechanism w in the brake-cleanet solvent and a small acid brush. After it's super clean lube with PB Dry Teflon spray ( sold at Home Depot next to the PB Blaster)
mmascari
Oct 25 2016, 08:37 PM
Thanks Jim....I figured as much. Thanks for the advice on cleaning and lubricant
steuspeed
Oct 25 2016, 08:45 PM
Sticky mechanism will lead to broken door handles. Definitely clean and lube that.
jim_hoyland
Oct 25 2016, 09:15 PM
Your old spring may be in the bottom of the door
Pics
mmascari
Oct 25 2016, 09:19 PM
I guess I will hit Parts Heaven tomorrow to get a spring.
