Engine Cradles - Your pics and thoughts, Taking my motor out to finish assembling carbs and work in bay |
NS914 |
Oct 27 2016, 04:16 PM
Member Group: Members Posts: 198 Joined: 9-June 09 From: Dartmouth, Nova Scotia Member No.: 10,455 Region Association: Canada |
Hey Everyone,
I am looking for your thoughts and pics of course re Engine Cradles you have assembled. I am finishing off the wiring for my car and will assemble the Webers as well and likely do a few other things while it is out. This will likely be a month or two of work and I want to locate my engine on a safe and stable cradle that I can then lift the engine from and reinstall. I don't think I have seen a thread re cradles so this should be interesting. As always, thanks for your thoughts and ingenuity. Grant |
Mark Henry |
Oct 28 2016, 12:17 AM
I use a scissor lift table like in the link below.
You just need a 2x4 across the engine bar and a block to level the tranny. Only PITA is you have to remove the handle...no big deal . But I also use a two-post lift, so my car is level and I have no issues with the car not being high enough. http://www.harborfreight.com/500-lb-capaci...cart-61405.html (IMG:http://www.914world.com/bbs2/uploads_offsite/www.harborfreight.com-26-1477635466.1.jpg) |
North Coast Jim |
Oct 28 2016, 07:07 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
I use a scissor lift table like in the link below. You just need a 2x4 across the engine bar and a block to level the tranny. Only PITA is you have to remove the handle...no big deal . But I also use a two-post lift, so my car is level and I have no issues with the car not being high enough. http://www.harborfreight.com/500-lb-capaci...cart-61405.html (IMG:http://www.914world.com/bbs2/uploads_offsite/www.harborfreight.com-26-1477635466.1.jpg) I also used the Harbor Freight hydraulic table. Worked like a charm with and without the exhaust mounted on the engine. It made this a one man job and no issues of the engine getting away from you. Had to jack up the car to get the proper height so I could wheel the engine in place. HB table is 9" high to the bed about the same for a jack system. I've used a hyd jack before on my 1st 914 engine pull years ago and that was NOT fun. As for building the engine up from the short block I used the small Harbor Freight engine stand. Had to do a little grinding on the mounting bosses to keep them from crushing the tranny mounting flange but that part was easy. |
Lo-Fi Version | Time is now: 13th May 2024 - 02:49 AM |
