Mid Rise Scissor Lift, Anyone have one by Atlas? |
Justinp71 |
Oct 28 2016, 12:13 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Hey guys (and gals). I know there are some older threads on this, but I am looking for a car lift that can go ~40" lift, doesn't need wooden ramps (for a 914) and doesn't break the bank. This Atlas lift from greg smith seems to come with shipping for $1745. Does anyone have this lift or something similar?
http://www.gregsmithequipment.com/Atlas-EM...se-Scissor-Lift Attached image(s) |
N_Jay |
Oct 28 2016, 12:33 PM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
I keep looking at this kind because I want to be able to get to the center of the car better. (For other cars.)
http://www.gregsmithequipment.com/Atlas-TD...le-Scissor-Lift |
somd914 |
Oct 28 2016, 12:50 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
I agree wth N_Jay's suggestion. I have a neighbor who has had that lift for several years sans any issues. The more open base is a plus.
As for Atlas in general, I've pleased with my two post lift. |
N_Jay |
Oct 28 2016, 01:03 PM
I have actually upped my looking to the 7000 LB lifts since the GL320 would be pushing the limits of the 6000 LB lift.
Next house is getting a tall garage! (More likely a separate working garage) |
GaroldShaffer |
Oct 28 2016, 01:10 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I keep looking at this kind because I want to be able to get to the center of the car better. (For other cars.) http://www.gregsmithequipment.com/Atlas-TD...le-Scissor-Lift (IMG:style_emoticons/default/agree.gif) That is the lift I have. If your 914 is stock or very close to stock ride height then you won't need ramps. If your car is lowered like mine, then yes you will. It really isn't a big deal to make up a set of ramps. Attached image(s) |
Justinp71 |
Oct 28 2016, 05:44 PM
Thanks guys, it does look like you have much better access. My car is pretty low, do the ramps get in the way when you are working on the car? i.e. are you always tripping over them, etc...? |
db9146 |
Oct 28 2016, 09:46 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
On the recommendations from some folks here, I bought a used Atlas 6000 over the summer for $900. Then built a couple of ramps from 2x10s (on top and a ripped 2x6 underneath) so I can park over it in the garage. When the car is in the air, I can just move the ramps out of the way if needed.
GaroldShaffer |
Oct 28 2016, 10:50 PM
When the car is in the air, I can just move the ramps out of the way if needed. (IMG:style_emoticons/default/agree.gif) That's what I do. It may take a try or two to get the right placement of the ramps so you car is centered and such, but once you have them where you want them just make a few marks on the garage floor for placement (I used a sharpe) and you are set. Most of the time I just leave them in place. |
mlindner |
Oct 29 2016, 05:39 AM
Senior Member Group: Members Posts: 1,517 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
JustinP71, just cut a hole in the cement.......Easy afternoon job, nothing to trip over. Mine has a cover I can drive over or raise as an additional 4 x 8 work area. Best, Mark
mlindner |
Oct 29 2016, 05:55 AM
Harpo |
Oct 29 2016, 06:20 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
JustinP71, just cut a hole in the cement.......Easy afternoon job, nothing to trip over. Mine has a cover I can drive over or raise as an additional 4 x 8 work area. Best, Mark Good morning mlindner (Mark) please elaborate on your weekend project to cut a hole in your garage floor. Thanks David |
mlindner |
Oct 29 2016, 07:00 AM
Harpo, I did have a friend to help....but the process went like this. Rent cement saw( the one I got was new with new blade) it cut the 6 bag mix almost as fast as cutting wood, could not believe. Then dug the sand out, down about 16 inches. The cement pour is a two step process, first pour base making sure it is level (my floor has a pitch to the floor drain). Then next morning framed up sides with a little rebar into the base. Second pour. Done.
I just used bag cement, and a little cement mixer that fit in the trunk of my wives Passat. If interested I can find pictures. NOTE, cutting cement is very dirty/dusty. I visqueened all sides of the garage off and had the hose/water going while cutting the cement. OK it took two days. still best thing I've ever done. Mark |
mlindner |
Oct 29 2016, 07:41 AM
913B |
Oct 29 2016, 08:44 AM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
My apologies to JustinP for the slight de-railment off the original lift in question.
What about this open scissor lift. Yeah its like $700 more, but you have better access to the center for other vehicles if you need to ? No I don't have one just been eyeing them since they announced free shipping. http://www.gregsmithequipment.com/Atlas-Kw...B-Mid-Rise-Lift |
Harpo |
Oct 29 2016, 09:21 AM
Sorry about the hijack Justin and thanks Mark for the photos. How thick is your new slab? It looks like you also cut a slot for your hydraulic line.
David |
mlindner |
Oct 29 2016, 12:54 PM
The old cement floor was only 3 1/2 inches thick with fiberglass imbedded, the new slab was 6 inches with a little rebar. Yes, sorry Justin, off the tracks we went.......mark PS with the scissor lift being lower in the floor, I can use the truck extensions for the lift making it possible to replace exhaust systems on newer VW Bettles and Jettas......for the Porsche's no problems.
Harpo |
Oct 29 2016, 03:47 PM
Did you tie the old cement to the new cement using rebar and holes in your new cement?
Thanks again DAvid |
mlindner |
Oct 29 2016, 04:33 PM
Hi David, no, no need for that. The base for the lift (slab) is so stable, maybe five times needed. The six inch poor on compacted sand is enough to lift a commercial truck. I can give you a little schematic of the cement layout if you want. Best, Mark
stevegm |
Oct 29 2016, 04:46 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
I keep looking at this kind because I want to be able to get to the center of the car better. (For other cars.) http://www.gregsmithequipment.com/Atlas-TD...le-Scissor-Lift (IMG:style_emoticons/default/agree.gif) That is the lift I have. If your 914 is stock or very close to stock ride height then you won't need ramps. If your car is lowered like mine, then yes you will. It really isn't a big deal to make up a set of ramps. And you have been happy with it for lifting 914s. I need to order one too and was thinking about this one. |
913B |
Oct 29 2016, 06:43 PM
Maybe we should do a group buy or something to get a price break ? (IMG:style_emoticons/default/confused24.gif)
Lo-Fi Version | Time is now: 6th May 2024 - 04:47 PM |
