Fuel pump problems, my fuel pump wont turn on anymore |
mxdude914 |
Apr 20 2005, 10:34 PM
Member Group: Members Posts: 134 Joined: 20-July 03 From: Lodi, CA Member No.: 925 |
It has done this a few times the fuel pump will just shut off in mid-drive then it wont come back on and usually i just try it a few times then it comes back on but not this time luckily i live in the country and i pushed it 1.5 miles home. Anyone know what could be causing this, also the fuel pump is new and it was relocted to the front of the car. Btw i am in highschool and have been thinking this is not the most reliable car, would it be smart to trade it in for like a later 944 or something of that nature, also if you have any car you might want to trade list it plz. The car is a Phoenix red 1973 2.0
TravisNeff |
Apr 20 2005, 10:43 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Sounds like your relay board needs some help. The ECU tells the fuel pump when to run - but it has to pass through the relay board to do so. The tar under the board can come loose and the connections behind it are at risk. Unless you have carbs and are running the pump off the coil or something - that is the first place I would look. You can scrape the tar off and resolder the connections.
mxdude914 |
Apr 20 2005, 10:47 PM
I looked at that already i just dont want to mess up the tar because it is in perfect shape. Should i just take it off anyways?
TravisNeff |
Apr 20 2005, 10:50 PM
If your pump is good/new as you say, wiring is good - double check your work after your relocation (check that first), then hit the relay board. You can get some other material to cover it back up. That board will work without any tar on it - go for it. You have FI, right?
mxdude914 |
Apr 20 2005, 10:58 PM
Ya i have stock f.i. on it. Tomorrow ill check the pump itself and do a bench test to see if its faulty then ill move on to the relay board. What do you think about my other question though, would a 944 be better for me since this will be a car driven to and from highschool every day.
Trekkor |
Apr 20 2005, 11:07 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Check the relay itself and the socket. the pins get corroded all the time.
KT |
Lo-Fi Version | Time is now: 20th May 2024 - 08:18 AM |
