WANTED Rear sway bar/shock bolts |
Jackstowers |
Oct 30 2016, 08:14 AM
Newbie Group: Members Posts: 2 Joined: 23-July 15 From: Kent, UK Member No.: 18,985 Region Association: None |
Hi
I'm looking for a pair of bolts that mount both the bottom of the shock and the sway bar drop link to the swing arm Thanks David |
914Sixer |
Oct 30 2016, 01:59 PM
Available from Porsche but NOT cheap.
ConeDodger |
Oct 30 2016, 02:56 PM
Apex killer! Group: Members Posts: 23,586 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Available from Porsche but NOT cheap. Do you recall how much Mark? I got mine from Rich Bontempi for $75 each! (IMG:style_emoticons/default/blink.gif) |
toolguy |
Oct 30 2016, 03:07 PM
Make your own. .
.750 chrome moly material with shaft turned to .562, counter sunk 1/2 inch depth in bolt with .0005 press fit and welded, then ball end turned. Attached image(s) |
Jackstowers |
Oct 30 2016, 03:08 PM
Available from Porsche but NOT cheap. Do you recall how much Mark? I got mine from Rich Bontempi for $75 each! (IMG:style_emoticons/default/blink.gif) Ouch!! |
Jackstowers |
Oct 30 2016, 03:16 PM
Make your own. . .750 chrome moly material with shaft turned to .562, counter sunk 1/2 inch depth in bolt with .005 press fit and welded, then ball end turned. That's great, thanks when will they be ready (IMG:style_emoticons/default/beerchug.gif) |
bdstone914 |
Oct 30 2016, 04:10 PM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Available from Porsche but NOT cheap. Do you recall how much Mark? I got mine from Rich Bontempi for $75 each! (IMG:style_emoticons/default/blink.gif) $85.75 each through Pelican. I think that is a price drop as last time I checked they were $120 each. You can also buy the ball shaft for the 1969-1973 911 trailing arm, shorten it and weld it on. I think those run $40 each. Not cheap or easy any way you go. |
914Sixer |
Oct 30 2016, 08:21 PM
Porsche part # 914 333 565.01
Lo-Fi Version | Time is now: 15th May 2024 - 11:19 AM |
