Hi I'm looking for a pair of bolts that mount both the bottom of the shock and the sway bar drop link to the swing arm Thanks David
914Sixer
Oct 30 2016, 01:59 PM
Available from Porsche but NOT cheap.
ConeDodger
Oct 30 2016, 02:56 PM
QUOTE(914Sixer @ Oct 30 2016, 03:59 PM)
Do you recall how much Mark? I got mine from Rich Bontempi for $75 each!
toolguy
Oct 30 2016, 03:07 PM
Make your own. . .750 chrome moly material with shaft turned to .562, counter sunk 1/2 inch depth in bolt with .0005 press fit and welded, then ball end turned.
Jackstowers
Oct 30 2016, 03:08 PM
QUOTE(ConeDodger @ Oct 30 2016, 12:56 PM)
Ouch!!
Jackstowers
Oct 30 2016, 03:16 PM
QUOTE(toolguy @ Oct 30 2016, 01:07 PM)
Make your own. . .750 chrome moly material with shaft turned to .562, counter sunk 1/2 inch depth in bolt with .005 press fit and welded, then ball end turned.
That's great, thanks when will they be ready
bdstone914
Oct 30 2016, 04:10 PM
QUOTE(ConeDodger @ Oct 30 2016, 01:56 PM)
$85.75 each through Pelican. I think that is a price drop as last time I checked they were $120 each. You can also buy the ball shaft for the 1969-1973 911 trailing arm, shorten it and weld it on. I think those run $40 each. Not cheap or easy any way you go.
914Sixer
Oct 30 2016, 08:21 PM
Porsche part # 914 333 565.01
