TDC, is yours the same? |
machina |
Apr 21 2005, 10:38 AM
this is where my TDC is marked but I have a different blower housing. Is yours at the same place on the bottom or is it just me?
Mueller |
Apr 21 2005, 10:54 AM
that looks right
Mueller |
Apr 21 2005, 10:55 AM
as for the marking on the bottom @ the 6:00 postition, I've never seen that placed there before...normally you have to look for the TDC thru the hole in the fan housing
Joe Ricard |
Apr 21 2005, 11:43 AM
I''ll bet sombody decided to make the mark easier to see. When your mark (in the pic) is lined up look through the hole in the fan housing should see the mark on the fan lines up in the V groove.
I assume you know what tool NOT to use to double check TDC of # 1 piston. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
d914 |
Apr 21 2005, 12:10 PM
uuoh, uoooh,,,,,,,CHOPSTICKS (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif)
machina |
Apr 21 2005, 01:35 PM
this housing doesn't have a port to view at the top, that's why I'm asking. Guess I'll use a chopstick. |
Jake Raby |
Apr 21 2005, 02:06 PM
Mueller,
Youv'e never seen a fan housing like that one either I bet..... what secrets that baby holds within it's confines! (It didn't come from a Porsche) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) There is no hole in top of it and thats why TDC is marked on the other end of things... |
Joe Ricard |
So how the hell are you going to time that thing? I suppose you could use the template on PP and do it upside down? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Chopsticks ha ha ha I crack me up. You know I'd a never admitted that |
Jake Raby |
Apr 21 2005, 02:28 PM
Nope, you can see it perfectly from under the car... or even from the top side shooting down with a timing light...
Reiche |
Apr 21 2005, 02:34 PM
Member Group: Members Posts: 169 Joined: 13-October 04 From: Vista, CA Member No.: 2,934 |
Is it a Vanagon shroud? A friend of mine had a Vanagon and I remember wondering where the timing access hole went.... |
machina |
Apr 21 2005, 03:57 PM
yup |
Jake Raby |
Apr 21 2005, 04:24 PM
It's been Rabyized too............
machina |
Apr 21 2005, 04:31 PM
just wondering about TDC... does it have to be spot on within say less than 1 deg when looking at the fan or flywheel? can it be off a little bit either way and still have both valves on the cylinder fully closed? |
opera guy |
Apr 21 2005, 06:53 PM
Member Group: Members Posts: 337 Joined: 28-June 04 From: upland, ca Member No.: 2,268 |
LMFAO |
Reiche |
Apr 21 2005, 07:21 PM
What do I win? A Rabyized shroud? (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) |
TheCabinetmaker |
Apr 21 2005, 07:26 PM
Damn, Opera guy, you ain't never gonna live that one down!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
Lo-Fi Version | Time is now: 12th May 2024 - 11:33 AM |
