Painting question |
Painting question |
Sea Dragon 914 |
Nov 1 2016, 12:10 PM
Member Group: Members Posts: 114 Joined: 26-February 03 Member No.: 358 Region Association: Northern California |
I'm refinishing some of my wheels and have questions about paint. I'm not sure if this is where to ask.
I am using a two stage paint to refinish some wheels. I've stripped the wheels to bare metal and used a bare metal primer. I let that sit for a few days and then sprayed three base coats. I let them cure overnight and then sprayed a coat of clear. There were a couple areas that the paint wrinkled pretty badly. Most of it looked good. I wet sanded to see what happened as I figured I'd reshoot the wheel anyway and it looks like where it wrinkled, the primer actually pulled away from the metal. Why did it wrinkle? Did I not let the primer and/or base dry enough? Should I have sprayed the base directly on the metal? This is practice as I'm hoping to shoot one of my cars. Thanks |
Lo-Fi Version | Time is now: 27th May 2024 - 02:04 PM |
