QUOTE(porschetub @ Nov 1 2016, 11:57 AM)
QUOTE(Sea Dragon 914 @ Nov 2 2016, 07:10 AM)
I'm refinishing some of my wheels and have questions about paint. I'm not sure if this is where to ask.
I am using a two stage paint to refinish some wheels. I've stripped the wheels to bare metal and used a bare metal primer. I let that sit for a few days and then sprayed three base coats. I let them cure overnight and then sprayed a coat of clear.
There were a couple areas that the paint wrinkled pretty badly. Most of it looked good. I wet sanded to see what happened as I figured I'd reshoot the wheel anyway and it looks like where it wrinkled, the primer actually pulled away from the metal.
Why did it wrinkle? Did I not let the primer and/or base dry enough? Should I have sprayed the base directly on the metal?
This is practice as I'm hoping to shoot one of my cars.
Thanks
When I strip alloy wheels right back to the metal I like to etch prime them,no question the paint sticks better.
How much primer did you put on,you only need a few thin coats,if you put on too much the solvents in the topcoat can eat through and cause your problem.
I like to put on one or two thin topcoats and leave it overnight,a quick sand next day and you build up to a wet shiny finish.
Did you use paint prep/degreaser before putting the primer on ?
It wasn't incompatible paints as it was only a spot or two and I've seen what happens when one paint is hotter than another.
It sounds like I put too much primer on as I did three coats. I did use a paint prep and degrease as there were no problems with orange peel or fish eyes. The wrinkle was in a few spots where I'm sure the primer was the thickest and I sprayed a heavy clear which probably went through the base.
Beauty is, I'll strip them again and redo! Practice, practice, practice and thanks!
