Turn signals not working!, Just quit the other day |
JRust |
Jun 24 2003, 07:30 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Going home to mess with it tonight. It seemed like the switch acted a little funny the day it quite. Kinda stuck & then went to turn. Where should I start? Fuses looked ok. I'll check thru the hanes troubleshooting too! Probably something small & dumb (IMG:style_emoticons/default/rolleyes.gif)
ChrisReale |
Jun 24 2003, 08:06 PM
when you try to use the turn signal, does the lights on the tach just light up? Or do you get nothing? Take the wheel off, and see if something came undone on the turn signal switch
ninefourteener |
Jun 25 2003, 09:32 AM
Perfectly Normal Guy :) Group: Members Posts: 1,216 Joined: 3-June 03 From: St. Louis, MO Member No.: 779 |
Agreed.... there's a little c-clip kinda thingy under the wheel...... mine got a little out of shape once, and it wasn't making contact, so my left TS didn't work.
This is, of course is after you check the fuses---LOL (IMG:style_emoticons/default/driving.gif) |
JRust |
Jun 25 2003, 06:52 PM
I did check the fuses first off. No such luck. DIdn't get to screw with it last night so hopefully tonight. I am getting nothing inside the car for turn signals. You know I just assummed I don't have them working out front (IMG:style_emoticons/default/wacko.gif)
Lo-Fi Version | Time is now: 13th May 2024 - 08:38 AM |
