Going home to mess with it tonight. It seemed like the switch acted a little funny the day it quite. Kinda stuck & then went to turn. Where should I start? Fuses looked ok. I'll check thru the hanes troubleshooting too! Probably something small & dumb
ChrisReale
Jun 24 2003, 08:06 PM
when you try to use the turn signal, does the lights on the tach just light up? Or do you get nothing? Take the wheel off, and see if something came undone on the turn signal switch
ninefourteener
Jun 25 2003, 09:32 AM
Agreed.... there's a little c-clip kinda thingy under the wheel...... mine got a little out of shape once, and it wasn't making contact, so my left TS didn't work.
This is, of course is after you check the fuses---LOL
JRust
Jun 25 2003, 06:52 PM
I did check the fuses first off. No such luck. DIdn't get to screw with it last night so hopefully tonight. I am getting nothing inside the car for turn signals. You know I just assummed I don't have them working out front
