front main seal - should I or shouldn't I, "might as well" or "leave well enough alone"? |
iankarr |
Nov 4 2016, 11:54 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
Been really trying to tighten up the miscellaneous leaks on my 2056. What I thought was a leak from a bad front main seal looks like it is actually caused by a partially disintegrated oil pump gasket. See pic below. I don't see evidence of an active leak from the main seal, but there is some sticky oil residue around it. My general approach to old cars is not to fix something that aint broke, or risk messing something else up in the process. But since the motor is out and I have all the stuff to replace the seal (and the oil pump gasket), do you think it's a good idea to replace the front? Or leave well enough alone? FYI, the motor was last gone through about 10 years ago. Thanks! |
Lo-Fi Version | Time is now: 19th May 2024 - 12:44 AM |
