> 2.0L engine Tin diagram?
Boomingbeetle
post Nov 4 2016, 02:44 PM
I am gathering up engine tin to install on a long block, but I'm not sure what I am missing. Diagrams are not as easy to find as the type one. I want to get all pieces powder coated at once. Here are some pictures of what I have. Not pictured- oil cooler, thermostat, fan pully, and the piece that goes above the flywheel.
Boomingbeetle
post Nov 4 2016, 02:46 PM
euro911
post Nov 4 2016, 03:22 PM
Items I don't see in your pix (or the list of parts you state you have)
There are two pieces across the front of motor, attaching to the fan housing and cylinder top tins
(IMG:http://www.914world.com/bbs2/uploads/post-7300-1474145778.jpg)
There are also two warm air guide plates that attach under the push rod tubes not shown. A lot of folks don't run them, but if you want a correct complete set, you will need those too ...
bdstone914
post Nov 4 2016, 03:28 PM
bdstone914
QUOTE(euro911 @ Nov 4 2016, 02:22 PM) *
Mark,
You are correct that the warm air guides are not there.
To the OP: Are you using the late 75-76 heat exchangers or earlier ones? You have both early and late J tubes in the picture. The warm air guides are different for early and late heat exchangers. I should have either set. You are much better off with the early heat exchangers. What exhaust are you going to use? That affects which heat exchangers are used.
You can download the whole Porsche PET catalogs here:
http://www.porsche.com/usa/accessoriesands...partscatalogue/
barefoot
post Nov 4 2016, 03:41 PM
The PET is you friend, look at illustrations 115-00 & 115-05 for engine tin
Boomingbeetle
post Nov 4 2016, 05:33 PM
QUOTE(bdstone914 @ Nov 4 2016, 02:28 PM) *
Is that Bruce? Now I recognize you. I bought a pair of seat height adjuster mounts from you at the swap meet a few weeks ago at your shop. I'm not going to run exchangers at all, I haven't purchased an exhaust yet, but it will have headers (IMG:style_emoticons/default/smile.gif). If it's chilly, I'll put on a sweater! I'd gladly trade all the heater components for the tin I am missing (the front piece in the photo, and the piece above the flywheel)
Boomingbeetle
post Nov 4 2016, 05:36 PM
I do have the guide plates, they are installed in the motor already. I do not have the piece you show
euro911
post Nov 4 2016, 05:56 PM
QUOTE(bdstone914 @ Nov 4 2016, 02:22 PM) *
Put on your glasses Mark. The top tins a next to the fan shroud. The under cylinder tins are there. You are correct that the warm air guides are not there.
I see you found YOUR glasses and edited your original post, Brucey (IMG:style_emoticons/default/slap.gif)
(IMG:style_emoticons/default/poke.gif)
(IMG:style_emoticons/default/welcome.png) Boom ... nice looking motor you're building up (IMG:style_emoticons/default/thumb3d.gif)
Boomingbeetle
post Nov 4 2016, 06:16 PM
QUOTE(euro911 @ Nov 4 2016, 04:56 PM) *
Mark, I've built a few in my day but I can't take credit for this one. I bought it as is, never installed from a project that stalled out and the owner needed to sell. It was built for a 356, so there are a few things I needed to swap.
bdstone914
post Nov 4 2016, 08:34 PM
bdstone914
[/quote]
Yes it is me.
I dont need more heater tin. I will have to check for the front tin parts. Nor sure if Mark has the ones he pictured or was just oosting a picture to show the missing parts.
Bruce
euro911
post Nov 4 2016, 09:15 PM
Yeah, pic was from a previous F/S ad. I sold most of my 'spare' tins earlier in the year. I'll look around to see if I have any more hiding somewhere, but I doubt it.
Drex
post Sep 15 2023, 05:01 AM
hello
in the 914PetE PDF above
all the illustrations say
year is 76
does this apply to all 914s
or is there a different PET for 1971?
thanks
D rex
Dave_Darling
post Sep 15 2023, 05:10 AM
914 Idiot
The PET should contain all years. There will be an application column denoting what car type (914, 914-6) or what engine size (1.7, 1,8, 1.8V, 2.0) and in some cases a note about what year or VIN range the part is for.
--DD
- Lo-Fi Version Time is now: 23rd September 2026 - 01:23 PM
