Adding a 915 trans to a 6 conversion, There must be a better way |
mepstein |
Nov 5 2016, 07:46 AM
914-6 GT in waiting Group: Members Posts: 19,277 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Is there any reason I shouldn't consider working up a cable shifter instead of the traditional 916 shift linkage. The current 916 kit is $3-3250. Add in labor for machining and assembly and you're at $5k just to make the trans shift correctly. The suby guys are doing the shifting with $300 worth of cables and hardware. Am I missing something here?
mepstein |
Nov 5 2016, 08:18 AM
Yes, flipping the ring and pinion is a given. That will be done when I rebuild the trans. But it came out of a running car so I'm not expecting many surprises. Good point about a muffler but I can build that around the shifter. If I can save $5k on the trans mods (and still have a great setup) that's pretty significant.
Lo-Fi Version | Time is now: 20th May 2024 - 04:14 PM |
