Adding a 915 trans to a 6 conversion, There must be a better way |
mepstein |
Nov 5 2016, 07:46 AM
914-6 GT in waiting Group: Members Posts: 19,277 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Is there any reason I shouldn't consider working up a cable shifter instead of the traditional 916 shift linkage. The current 916 kit is $3-3250. Add in labor for machining and assembly and you're at $5k just to make the trans shift correctly. The suby guys are doing the shifting with $300 worth of cables and hardware. Am I missing something here?
rgalla9146 |
Nov 6 2016, 11:33 AM
Advanced Member Group: Members Posts: 4,559 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Attached are pictures of a hangar and an idea for linkage that I fabricated to install a 915 in a 914 chassis.
I've since switched to the kit that Martin Bott makes that duplicates 916 parts. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 12:07 PM |
