Adding a 915 trans to a 6 conversion, There must be a better way |
mepstein |
Nov 5 2016, 07:46 AM
914-6 GT in waiting Group: Members Posts: 19,277 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Is there any reason I shouldn't consider working up a cable shifter instead of the traditional 916 shift linkage. The current 916 kit is $3-3250. Add in labor for machining and assembly and you're at $5k just to make the trans shift correctly. The suby guys are doing the shifting with $300 worth of cables and hardware. Am I missing something here?
Steve |
May 27 2017, 11:14 AM
914 Guru Group: Members Posts: 5,589 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
It's only money.. I have 10k in my Martin Bott 86 gear box. At least it's not a jury rigged mess. Same as factory and works great.
A Boxster S trans would be better if someone made a kit?? Hint.. hint.. it can be done. I've seen a 3.6 car with one awhile back. The 915 is harder to shift than a 914 trans, but having a trans with gears that match the motor is priceless |
Lo-Fi Version | Time is now: 20th May 2024 - 02:15 PM |
