Removing stub axle from hub, Tips and tricks welcome |
RustyWa |
Apr 21 2005, 11:20 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
So I got the 30mm nuts removed from my stub axles. The half shaft on the passenger side came out of the hub easy as cake but, the drivers side will not budge. I've beat the hell out of it with a 3 lb. hammer and brass drift, soaked it with PB blaster, put the nut on backwards and beat on it. Nothing has worked. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) I would like to get it out without destroying the bearing.
I've got an air hammer with a pointed chisel I've been thinking about trying, by placing in the hole in the center of the stub axle. I'm afraid it might mushroom out the stub axle. Any suggestions? I need some moral support. |
Joe Bob |
Apr 21 2005, 11:30 PM
PB blaster...heat, wait a day...come back.....shoot it with a .357...
The gun part won't help but will make ya feel better... Keep soaking it...you might have to remove the whole arm and press it out. |
markb |
Apr 21 2005, 11:32 PM
Sounds like you're doing it right. It just may take some time (hours, days, weeks (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) ) until the sucker comes loose. Bondo & I wound up using a puller to push a stub out. Keep at it.
RustyWa |
Apr 21 2005, 11:41 PM
True, true. I'm planning on removing the arm anyways, so maybe pressing it out is the answer. |
SpecialK |
Apr 22 2005, 12:10 AM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
Yeah, I did mine on the bench, no press required. I think that some of the "ass" of the maul is absorbed by the rubber swingarm bushings. Get it on a solid surface and you'll have better luck (or at least a better angle for beating the hell out of it.... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) ). Stick with the brass drift for whipping it into submission, I'd almost bet that your chisel and air hammer will have some ill effects on the stub axle....especially if it pops out of the divot (IMG:http://www.914world.com/bbs2/html/emoticons/pinch.gif) . That said, after a good douching with PB, a little vibration set up by some "mild" hammering with the pneumatic might be beneficial in getting the PB where it needs to be, reducing the overall amount of whoopin' required with the BFH.
If it's that stuck, the odds of getting the stub out without damage to the bearing are not good. Might as well bite the bullet (.357) and but a new pair. |
sj914 |
Apr 22 2005, 12:49 AM
I used a bigger hammer while it was on the car.
Eric_Shea |
Apr 22 2005, 10:54 AM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
MAPP torch the piss out of it and PB Blaster it some more.
Cap'n Krusty |
Apr 22 2005, 11:06 AM
You've already damaged the bearing by beating on the assembly, so whack away on it. Stub axles are plentiful .........
The Cap'n |
Eric_Shea |
Apr 22 2005, 11:09 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) I've got an extra if you need it.
URY914 |
Apr 22 2005, 11:11 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,426 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Pull like crazy on the axle from the inside. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
OK, maybe not. Bigger BFH will work. Paul |
Root_Werks |
Apr 22 2005, 11:28 AM
Village Idiot Group: Members Posts: 8,315 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Yep, bearing is toast now anyway. I use a slide hammer when I have to. Works great. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
RustyWa |
Apr 22 2005, 12:47 PM
ack! |
RustyWa |
Apr 22 2005, 05:28 PM
Ok got it out. I used a little more hammering, PB Blaster and some heat. Now just to add a bearing to the list.
I'll sure be putting anti-sieze on the stub axles before putting them back in. Thanks all. |
airsix |
Apr 22 2005, 06:54 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Sorry I didn't get here in time... Anyway, next time go to Schucks* and for about $3 you can rent a hub puller. You attach it's fingers to the hub with lug bolts and then just turn the center bolt to push out the stub axle. For another $3 you can rent their slide-hammer which you can then attach to the hub puller (after removing the center bolt) and three good whacks will have the hub pulled too. With these two tools you can have the stub and hub out in just a minute or two.
-Ben M. *for you non-Washingtonians that's our FLAPS chain. |
Lo-Fi Version | Time is now: 7th May 2024 - 11:08 AM |
