V8 headers - what works best?, Thinking about stock Corvette |
tygaboy |
Nov 11 2016, 01:19 PM
914 Guru Group: Members Posts: 5,292 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Hey V8 guys -
I need to get headers for my LS3 conversion. I'm thinking about trying the stock Corvette headers (pictured) as the collector is a bit father forward, giving me some additional room. A buddy of mine did an SBC swap and had a heck of a time getting the right fit with standard headers. So... what works, what should be avoided? (IMG:style_emoticons/default/confused24.gif) Thanks! Chris Attached thumbnail(s) Attached image(s) |
Mike Bellis |
Nov 11 2016, 01:34 PM
Don't they hake a tube shorty header for the same car? Cast headers usually suck.
v82go |
Nov 11 2016, 02:07 PM
Resident Contrarian Group: Members Posts: 249 Joined: 9-December 04 From: Lakeland, Fl. Member No.: 3,250 |
I am running long tube F-body headers on my LS6 (C5) conversion, they are stainless now ceramic coated. I bought them off of ebay for not much $$.
Not sure if they are LS3 compatible. Bob Attached thumbnail(s) |
cwpeden |
Nov 11 2016, 03:42 PM
Just google SBC Shorty headers: https://www.google.ca/search?q=shorty+heade...ers&imgrc=_
andys |
Nov 11 2016, 04:18 PM
I favor the OEM headers, as they come with heat shields and don't tend to leak like aftermarket headers. Those LS3 (Vette) headers are what I recommended to a friend, as the exit points in a favorable direction (some LSx headers point straight towards the axles), so that center exit is good. They support 400+HP, and are surprisingly light. For my own LS1 swap, I used LS6 Vette headers. See post #54 here: http://www.914world.com/bbs2/index.php?sho...04625&st=40
Andys |
moorepower |
Nov 11 2016, 04:49 PM
Member Group: Members Posts: 55 Joined: 9-May 15 From: eastern Nebraska Member No.: 18,718 Region Association: Upper MidWest |
On Youtube right now there is a Dyno test with manifolds, midlength and long tube. They are testing an LS. Sorry I don't have a link, but it's an easy search.
tygaboy |
Nov 11 2016, 05:45 PM
Awesome - thanks to each of you! Seems, as with most thing, I have options. The exhaust routing I'm planning likely benefits from the stock manifold set up.
And here's that YouTube comparo vid: https://www.youtube.com/watch?v=Y7_lSU3D0jw Long tubes would be great but I don't think I have room. I'll post details in my Build Off Challenge thread as I get to the exhaust. Thanks again! The World comes through, as always. (IMG:style_emoticons/default/aktion035.gif) |
whitetwinturbo |
Nov 11 2016, 10:17 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
I think you may be happier with "real" even length headers. However, mine are "long" format which creates problems with axle clearance. Shorter allows more room to get above or below the transaxle.
whitetwinturbo |
Nov 11 2016, 10:19 PM
BIGKAT_83 |
Nov 12 2016, 04:59 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
tygaboy |
Nov 12 2016, 09:08 AM
After viewing that video (link above) and am leaning toward the cast LS3 vette manifolds: good performance and ease of fitment.
It's not like I'm looking for absolute maximum power (blasphemous, I know). Thanks again, folks! |
Cracker |
Nov 12 2016, 03:20 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Usually they do but these don't...my old LS2 made an honest 515 CHP on the cast C6 manifolds years ago. Cheap and easy Chris!
Chris - Below is a picture of how I ran my exhaust with those manifolds - easy and straight forward. Tony Don't they hake a tube shorty header for the same car? Cast headers usually suck. |
timothy_nd28 |
Aug 11 2017, 12:06 PM
I think I will also go the LS3 exhaust manifold route. They have a muffler which has 4 ports, two inlets and two outlets. Does this act as a H pipe? I'm not after max horsepower but rather a quiet ride with no or little droning.
Is it better to run all pipes into one muffler, or run mufflers on each branch and keep each side independent? |
Lo-Fi Version | Time is now: 18th May 2024 - 12:39 AM |
