How about some intake/engine soft-porn, Aaand some questions |
draganc |
Nov 15 2016, 11:20 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi folks!
Finally making some progress on my 2056 project. I'm in the early setup stage and have some flow dynamic questions for the public: My ITB are ID 45mm, manifold 47/36 and my 2L heads 36mm. Do you guys believe that the 45 to 47mm step will cause some issues? Also, the intake's outer bolt area has too much "meat" for the head studs - market red. I was thinking of grinding down the extra material. Last but not least, what's a good place to source 45/36mm intakes? Thanks for your feedback! |
draganc |
Nov 15 2016, 11:21 PM
whitetwinturbo |
Nov 15 2016, 11:34 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
love auto porn (IMG:style_emoticons/default/sheeplove.gif)
draganc |
Nov 15 2016, 11:40 PM
Yo! No touching, just looking!! |
Mueller |
Nov 16 2016, 12:37 AM
tygaboy |
Nov 16 2016, 07:32 AM
914 Guru Group: Members Posts: 5,291 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
(IMG:style_emoticons/default/wub.gif)
LOVE IT! There's just something about ITBs... Please keep posting - I'm interested to see the system come together! Keep it up! (IMG:style_emoticons/default/aktion035.gif) |
McMark |
Nov 16 2016, 08:25 AM
Almost every carb install has that same step. It's not ideal, but it'll work. What about different manifolds? There's 4 or 5 different kinds. You might kill two problems at once.
rhodyguy |
Nov 16 2016, 11:30 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I think the boss is thinner on the CB talls.
HAM Inc |
Nov 16 2016, 11:43 AM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
That looks great! Love the ITB's.
I remember those manifolds. I still have some. I preferred them for my race engines. The 2mm step won't hurt flow. Even with a carb set-up (wet flow) the step isn't an issue. I would just pull the studs out of the head and replace with longer studs. Lot of work to machine that material away. |
Tbrown4x4 |
Nov 16 2016, 11:48 AM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
I have a the same stubby manifolds. Always wondered what they were off of. Any advantage/disadvantage to using the short manifolds?
Sorry if this is a hijack. I just wondered if you're using them for any particular reason such as performance or clearance, or just because that's what you have on hand. |
draganc |
Nov 16 2016, 11:53 AM
That looks great! Love the ITB's. I remember those manifolds. I still have some. I preferred them for my race engines. The 2mm step won't hurt flow. Even with a carb set-up (wet flow) the step isn't an issue. I would just pull the studs out of the head and replace with longer studs. Lot of work to machine that material away. Thanks for the suggestions. Do you sell longer studs by any chance, respectively, any suggestions where to get them? |
McMark |
Nov 16 2016, 01:18 PM
I just cut you a set of longer studs, and I already have your address.
But I also realized (based on our off-forum emails) that you won't be able to use these manifolds and my coil mounts. The coil mounts might work on a 'normal' set of manifolds. |
McMark |
Nov 16 2016, 01:19 PM
Checked a set here. Different manifolds will work. You need to pick if you're going to use the coil mounts or the manifolds you have.
Elliot Cannon |
Nov 16 2016, 01:54 PM
Hi folks! Finally making some progress on my 2056 project. I'm in the early setup stage and have some flow dynamic questions for the public: My ITB are ID 45mm, manifold 47/36 and my 2L heads 36mm. Do you guys believe that the 45 to 47mm step will cause some issues? Also, the intake's outer bolt area has too much "meat" for the head studs - market red. I was thinking of grinding down the extra material. Last but not least, what's a good place to source 45/36mm intakes? Thanks for your feedback! Who makes this system. I'm growing tired of my Webers. Or maybe I just need another project. (IMG:style_emoticons/default/biggrin.gif) |
draganc |
Nov 16 2016, 03:08 PM
Checked a set here. Different manifolds will work. You need to pick if you're going to use the coil mounts or the manifolds you have. Thanks for the double-check and the "other" picture. makes perfect sense now. As in regards to "Different manifolds will work", which one did you use? |
draganc |
Nov 16 2016, 03:09 PM
Who makes this system. I'm growing tired of my Webers. Or maybe I just need another project. (IMG:style_emoticons/default/biggrin.gif) extrudabody, but they are going out of business. i'll sell you my set for $20k and a six pack. yes, deal? (IMG:style_emoticons/default/beerchug.gif) |
draganc |
Jan 2 2017, 09:27 AM
I just cut you a set of longer studs, and I already have your address. But I also realized (based on our off-forum emails) that you won't be able to use these manifolds and my coil mounts. The coil mounts might work on a 'normal' set of manifolds. McMark delivers! Thanks a lot for the longer studs!! (IMG:style_emoticons/default/beerchug.gif) Just had to slightly open up the holes on the manifold and it fit's perfectly now. What kind of gasket would you guys use, for in between the ITB and the manifolds? I found some thin paper gasket I had - see in the pic. Anything better out there? Happy New Year to everybody! |
McMark |
Jan 2 2017, 09:43 AM
Glad it worked out. The paper is about the only thing out there. If you wanna get super fancy, have grooves for o-rings cut in. But really, don't bother. The paper is fine.
Lo-Fi Version | Time is now: 14th May 2024 - 05:27 AM |
