3.2 conversion wiring, Maybe someone can tell me what these are before I hunt them down |
914dave |
Nov 23 2016, 05:30 AM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
This is a section of the DME harness from my 1987 3.2. Pictured are
1) 6 pin connector that plugs into the sub harness for alt/starter/reverse light 2) O2 sensor 3) a rubber relay socket 4) a single black and a single green wire with eyelet terminals I'm assuming that the O2 sensor and the other wire go thru the sheet metal to the exhaust area. I don't know what the green and black wires go to. The relay socket is easy. Do you guys know before I have to hunt it down. I haven't been able to find a good harness diagram that has good enough resolution to print out. Thanks Dave |
jim912928 |
Nov 23 2016, 06:56 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Here is the link on how I wired up my 3.2L conversion (should be close....it's an 84 3.2l)
http://www.914world.com/bbs2/index.php?sho...7&hl=wiring |
914dave |
Nov 23 2016, 07:44 AM
Here is the link on how I wired up my 3.2L conversion (should be close....it's an 84 3.2l) http://www.914world.com/bbs2/index.php?sho...7&hl=wiring Jim Thanks for posting that thread. It is very informative. But the ones I'm looking at are at the engine bay end of the harness. Not covered in your thread that I can tell. Dave |
Nov 23 2016, 07:55 AM
Are the green and black wires for the coil?
914dave |
Nov 23 2016, 08:12 AM
Nov 23 2016, 10:16 AM
Are the green and black wires for the coil? Mark It might be. I was a little confused because it was so close to the O2 sensor. But it may have dropped down thru the tin in the 911 into the top of the heat exchanger. I'll check it out. Thanks Dave Attached image(s) |
914dave |
Nov 23 2016, 11:41 AM
Are the green and black wires for the coil? Mark It might be. I was a little confused because it was so close to the O2 sensor. But it may have dropped down thru the tin in the 911 into the top of the heat exchanger. I'll check it out. Thanks Dave That looks like them. Thanks for the pic. |
Lo-Fi Version | Time is now: 16th May 2024 - 07:33 PM |
